Your calculator is fine. It is an adding machine first, so it uses adding machine logic and you hit the star button to print the total on the tape. The equals sign is only used when multiplying and dividing.
Adding machine logic is as follows:
5+ total 5
3- total 2
7+ total 9
* print out total
It probably uses adding machine logic. Try the following example.
3+
4-
5+
You should get 3, -1, and 4 on the screen, the running total. The tape should show the +3, -4, +5, and finally 4, the numbers that you entered and the total. Think of each entry as adding/subtracting integers on a number line rather than 3+4-5;)
99% chance to have it fixed by replacing the main board. 1% left for the power board and if it's the later it can probably be fixed by replacing a few capacitors on the board.
But that is much less likely.
Main boards go for about $60 and you can totally do it all by yourself, even if you are pregnant.
There's a website that has all this information about all this and manuals everything totally free there are many actually but I personally like few ..
let me know if u need help
thanks
2. Locate the small round reset button near the left side of the circuit board (Red or Black).
3. To program, press the reset button once, then enter your 4-8 digit code on the exterior keypad, then immediately press the middle lock button on the exterior keypad. You will hear a beep. This signals that your code has been accepted.
4. To enter a second code, follow the same procedures as in step 3, but this time press the reset button twice then enter your code.
I don't know if this will help but I have a Samsung phone - (don't know the model number). if yours works similar to mine: To generate a call report I click the OK button and then scroll to Recent Calls - click on that and the last choice on that menu is View Timers - click on this and it should tell you the last calls time, your total calls time,, etc... I hope this helps!
I don't know which Ad blocker you are using but you'll need to find it and locate the 'Settings' tab. There, you'll find a list of the websites, web pages or ad URL's. Look for anything that says YouTube and remove it. If you're unable to locate it, you may have to remove all of them until you find the correct one.
Start by going to the toolbar on your browser and click on 'Tools'. Your Ad Blocker should be listed there. (Hopefully). Without knowing which one you have, I can't give you any other information. But, you should be able to figure it out for yourself after that. If not, re-post your question and let us know which Ad Blocker you have installed. (Make sure to check and see if you have more than one.)
Because this is an adding machine you would use the total button (*) not the = for ading and subtracting the = is only used in multiplcation and division
