Televison & Video Logo
l
latasha denise washington Posted on Jan 16, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need to know how to return non working equipment
Dont have model #
John Ray
Level 3:
  • Master 790 Answers
  • Posted on Jan 17, 2015
John Ray
Master
Level 3:
Answers
790
Questions
0
Helped
186463
Points
2180
Contact where to purchased the unit. If you have the ticket from the origanial purchase, it should not be a problem.
I have a monarch tagging gun 3030 model and I need a new needle. . Where can I find one? I don't know the number for the needle
If you search Amazon for "monarch tagging gun needles" you will get various options. It looks like they fit all guns (not model specific). Amazon's return policy is good so if they don't work for some reason you should be able to return them.
5answers
Suds blocked pump on bosch 800 series, tried to drain from drain hose, not much came put
More then Likely there is more then just a suds lock small objects can build up loose change all can be in pump housing poss even damaged prop on pump it self need full model # and serial # to say much more
1helpful
2answers
My gas lines have deteroiorated in the tank and need to know where to connect new hoses
Without knowing exactly what make and model here is a generic fuel line setup using a remote primer.
Apr 03, 2015 • Garden
I have a Smith Cornona Electra XT. It still turns on, but when I do turn it on, the carriage automatically goes back and forth non-stop and it's like you arre holding the return button down conti
Find the problem, some linkage is sticking and you have to trace it through. Spray with WD40, then when working spray with other light oil, cause WD40 does not stay. Most likely the carriage return release . Take bottom off and watch what it hits on the left side, Also the tab button locked down will do this.
2answers
Roofing nailer not working
I dont know this particular piece of equipment but it sounds like a broken return spring
2answers
How do i know if my outside tap has a non - return valve i want to start using a pressure washer
Dear del_brenda_s,
I have been servicing Power Washers for the last 5 years. And I cannot understand why you need a non-return tap outside. I think "outside" you are refering to the main supply after the water meter.
Well if your power washer needs a non-return, you can fit a cheap garden hose non- return attachment.
Regarding the non-return at the outside tap,..this is most probably NON-RETURN. If you want to be sure you can contact the water works division of your country and city...and I am sure they know what sort of taps should be used. In my country it is a must that a non-return outside tap is used. This is important so that when there is a cut in the water supply, the water meter and the whole system will not have to be bled out of air when the water comes again.
Regards,
Fulltech.
2answers
Repair on Datacard sp35 locate in Houston Texas
Do you have found a repairer for your datacard ?
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
