I would clean out the bobbin area again after oiling. Also, follow the thread path and clean the part that moves back and forth below the pressure/feed mechanism by the bobbin. I have used a vacuum on sewing machines and a blower to get hidden debris out.
Testimonial: "You are super, Myron. Used a vacuum attachment as you suggested and cleaned the bobbin area again using a soft cloth this time instead of a small brush. Black lint and oil is a wicked combination; I had to rub every nook and cranny before the thread would come out true. Thank you for helping a newbie."
Is the bobbin winder on? If so, turn it off.
Otherwise, is there power to the machine?
And this happened while you were sewing? Cut the thread above the needle eye. Rock the handwheel back and forth firmly to try to cut the thread jam below the needle plate with the sewing hook. If that doesn't work, open the bobbin case area of the machine and try to pull the bobbin case out, cutting any threads you can see with a seam ripper. Still won't come? Take the needle out of the needle clamp and throw it away (it's bent!), and take the screws out of the needle plate (=throat plate) and take the needle plate off after cutting any threads you can reach under the fabric. Keep cutting and pulling out any thread you find, and eventually, you'll be able to turn the handwheel. Clean all the thread bits, lint, and junk out of the area under the needle plate, the bobbin and bobbin case, and the shuttle area... there will be directions in your manual on how to clean the machine, including the shuttle area. Reassemble. Put in a brand new needle, right way around and fully up in the needle clamp. Rethread from scratch.
Always hold the thread ends behind the presser foot for the first couple of stitches of each seam.
See also: http://www.picturetrail.com/sfx/album/view/22521551
have you cleaned under the needle plate for lint also in the bobbin area for lint or loose threads make sure the bobbin is inserted correctly into the bobbin case make sure the bobbin is not warped try changing the needle try rethreading the machine top & bobbin if none of these suggestions work,, then it will be a good idea to have the machine checked at a repair shop
Change needle
Clean under needle plate where feed dogs are for lint
Clean bobbin area for lint or loose threads
Rethread machine top thread make sure to get every thread guide
& bobbin is threaded correctly & inserted in the bobbin case or shuttle correctly
Check tension 3 or 4 is usually good
after you try all this & it keeps jamming then it may need to be serviced
Change needle-flat side to the back of the machine
& make sure bobbin is wound correctly & that it is inserted correctly in the bobbin case or shuttle
with some machines the thread comes off the thread take up lever
clean under the needle plate where the feed dogs are for lint
also clean in the bobbin area for lint or loose threads
also check for burrs on the needle plate or on the bobbin & case
it could also be out of time
make sure the bobbin thread is wound and installed correctly
remove tangled thread and clean lint out from under feed plate
clean and remove shuttle to clean out area with lint brush
inspect bobbin for burs and scratches...make sure when reinstalling shuttle and bobbin that it rotates freely
hope this helps
From the Sears Kenmore manual:
Using a small brush, remove the lint that accumulates in the shuttle area and around the feed dogs.
To Clean the Shuttle Area:
This area must be kept free of dust, lint and occasional tangled thread. Raise the needle bar to its highest point and remove the bobbin case.
Push levers of shuttle race aside and lift shuttle race cover and shuttle out.
Clean the shuttle race with a small brush.
Put a drop of oil on the center pin of the shuttle and shuttle race.
sounds like it needs a service call. if you do not have a sewing repair man you use regularly to clean machine the local fabric store should know who you could call.
Do you mean it wont pick up the bobbin thread? You need to get into the user's manual on removing the bobbin shuttle that the bobbin holder clips into (actually pretty easy, I clean ours yearly especially if fuzzy material like velour is sewn) and brush the fixed area out that the bobbin shuttle floats in then reassemble and test. Also remove the throat plate/needle plate and you'll find that fuzz/lint gets between the plat and the feed dogs keeping the dogs from coming up fully.
Also if thread breaks one thing to look for if you've had needles break is a burr around the oval opening in the plate where the needle goes into it. Small Swiss file takes care of the burr and no more burr to break/cut the threads.
On rare occasions you may find the actual bobbin carrier (the one that holds the bobbin and is clipped into the machine) gets worn and wont stay clipped into the shuttle that holds it. Replacing the bobbin carrier is needed then. A1 Sewing on the net carries parts for the #1, #1+ etc.
