Dryer inglis model ih 82000 doesnt start at all was fine before I push on the start button but nothing ! thank you to answer my question
SOURCE: Whirlpool Dryer (LER7646E) not working
check your power cord and the receptcal if you see any discloring on pronges of your power cord you'll need to replace cord and the receptical it could be shorting out
SOURCE: Whirlpool dryer model LEQ8800JQ won't start when push start butto
I posted today (Jan 2, 2009) that I had same problem. Handyman tested for blown thermal fuse, etc and everything was fine. He said I have to replace the timer switch .. well guess what - I fidgeted with the start button (on/off) hard a few times while simultaneously pressing & releasing door switch and it did the trick. In my case the problem was most likely with the start button. Dryer is working fine now!
SOURCE: Kenmore Dryer stop running when release the start button
I have whirlpool dryer, when i push the start button it will start but only stay on for part of the drying time. no the start button make noise when push and after keep trying it stop.
SOURCE: Dryer won't start.
Would first check the Breaker panel Breaker and see if it is tripped. Try resetting, if it trips out immediately would call an electrician.
SOURCE: dryer wont come on and light on the inside doesnt come on
this could be that your belt is broken there is a switch when the belt breaks it stop working thanks from gilles
