The night service button does not highlight when pressed. We can set voicemails on individual phones, but cannot get incoming calls to divert to 1 phone for the voicemail to work. Please Help!!
SOURCE: Voicemail box not set up
I have seen the same problem with some users (I look after the PABX) so I just go into the maintenance console and set up the foreward to the default voice mail number. Or you can try the following:
CALL FORWARDING HANDSET
1. Press the Speaker Phone Key on your handset
2. Then Press the FWD/DND Key
3. Then select the Forward type you desire -
Key 2 - Immediate
Key 5 - Busy/No Answer
4. Then dial the internal extension number (eg.444) or voicemail pilot (201)
4a. If forwarding to external number dial 0 then dial outside telephone number
5. Dial # then press the Speaker Phone key
Use the voice mail that is set for your system.
Hope this helps
SOURCE: Panasonic KX-TVA50 Voicemail
Be still my heart! I'm coming to Indy on Tuesday afternoon!
It's not the 7731/TVA-50 that's bad for business, it's the TA-824. Don't tell my Accountant, Restaurant, Machine Shop, and small business customers that. They might want their money back :-)
Are there any blinking lights on the TVA when you reset it? It indicates lost integration. We make sure we plug both the VM and the system into the same power strip so that the systems can restart together. The laughable part would be that you have your offices cleaned on Friday evenings and a cleaning crew turns off the power or uses the outlet that the system is plugged into.
A message can be displayed by pressing the MESSAGE button on the phone when it's idle. All messages can be cleared by dialing 700 0.
Voice mail forwarding to a cell phone covers a broad spectrum. You can forward the fact there's a message, the file, or just notify the cell that there's a call. Two of the 3 requires the LAN card, but it also forwards to email. The dummy is the installer who didn't leave setup instructions for the voice mail system...or was he smart? Hard to say :-)
Last, If you want to touch base with me, I can be reached at [email protected] where I can give you contact information. My Indy trip may be by way of Columbus, OH if I don't get the remote system to respond to programming. The Panasonic system can be accessed via remote after programming so it may be that I can take over the system and make it work for you.
Carl
SOURCE: Activate voicemail service and night mode
Then it's miswired. Are you looking at a TVA-50 or TVS-50 voice mail? It should have two 4-pin cables wired to both 107 and 108 in both ports of the Voice Mail box.
SOURCE: Hi, I need help on
TVA and TVS systems have master passwords that the installer has. If you lost the password to 999, then your installer can probably come out and reset them. If you have lost the master password, Panasonic can restore that, but it's not easy.
If you happen to have the password for 998 and 999, you get there by pressing #6 *99x at the login. Put in your password and IIRC admin is option 5 or 6 in 999.
Carl
SOURCE: I HAVE A PANASONIC PHONE SYSTEM TDA 100 HYBRID IP
only 1 handset rings because in default only one extension is allocated as the operator -
you will nedd to enter system programming PROG * # 1234 AND SCROLL THROUGH PROGRAMMING
you will have to find -
group (enter the member you want to ring)
then aim DDI number at this group
or if analogue line then DIL to point to this group
