What should I do with my husqvarna 130BT because I put in too much oil with the gas and it won't start?
First, you need to dump all of the fuel out of the gas tank, Preferrably into a gas container. If you know how much oil you dumped in, you can calculate how much more gas to add. You could also just dump the gas, re-mix some new gas and oil, whichever you prefer.
If you are comfortable doing this, remove the fuel lines going to the carberator and let them drain into a pan. Pump the fuel primer to purge the gas out of the carburator, and then re-install the fuel lines. This might help you get it started a little faster, but its not necessary. You can burn the old gas in the engine at it will be fine.
Next, remove and replace the spark plug. Its probably fowled out with too much oil. Keep a can of carb cleaner and a small wire brush handy, you may need to clean the spark plug a couple times. If it gets too dirty, you can replace the spark plug with a new one. Do not burn Carb Cleaner in your engine for long periods of time, it will damage the engine.
After you have installed the spark plug and put some correctly mixed gas in the tank, Try to start the engine again. There will be some residual fuel in the fuel lines going to the carberator, so you will need to burn off that gas.
If you can't get it to start, try these steps:
Choke off, throttle wide open, crank several times. (or let it sit in the sun for a couple hours) (this corrects flooding)
Prime carberatur, Choke full on, throddle idle position, crank until it fires once but does not start.
Choke half, crank until it fires again or starts.
If it starts skip this step: (Choke off, crank until it starts).
Keep the choke on half for about 10 seconds and let it idle.
Put the choke off and let the engine warm up for a couple minutes.
After warmup, test the throttle to see if it will run at full throttle (it may take some fluttering until the engine is fully warmed up)
Let the engine run at full throttle for a few minutes. The exhaust may be a little more blue-smokey than normal...this is the excess oil burning...totally normal and harmless.
