Question about Ryobi Two 18V Lithium-Ion Batteries + Lithium-Ion Charger Upgrade Combo Pack
I currently live in Europe and have a Ryobi CHP-1802 drill with an 18 volt Li-Ion battery. The charger is a Ryobi BCL-1800 220 Volt, 50 Hz. I am moving back to the United States and want to keep thi
I currently live in Europe and have a Ryobi CHP-1802 drill with an 18 volt Li-Ion battery. The charger is a Ryobi BCL-1800 220 Volt, 50 Hz. I am moving back to the United States and want to keep this drill. Is there a 110 Volt charger that will fit the battery, charge the drill and not harm it? Where can I get this charger if it exists?
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 102 Answers
I agree. Bite the bullet and buy a replacement or replace the tool with a new kit. Finding good quality replacement cells is difficult. Cheap lithium ion cells usually have contaminants in the electrolyte so they won't last.
Posted on Sep 21, 2016
    Cheetah:
  • 55 Answers
After looking at the manual for your charger, it looks like most of the Ryobi chargers like the P113, P114, P117, P118 will charge your battery. The connector on the battery looks the same as the P103 and P104 used here in the U.S.
Posted on Jan 16, 2015
  • 1 more comment
  • Ngoro Jan 16, 2015
    Ryobi P103, P104, P113, P114, P117, P118 are not chargers but batteries.
    Ryobi P103, P104 are bateries, Ryobi P113, P114, P117, P118 are chargers.
    Top Expert:
  • 1,854 Answers
Use 110V/230V converter or transformer:
66results for 110v 240v converter
  • 1 more comment
    Use converter or transformer at least 85 Watt - better 100 Watt (Ryobi BCL-1800: INPUT 220-240 V 85W, OUTPUT 18V 3A)
    http://www.ebay.co.uk/itm/PRO-Power-Conv...
  • jogp98 Sep 21, 2016
    Simian AC-500 looks like it will do it. $30. Google it.
2 Suggested Answers
6ya staff
SOURCE:
theoisle
theoisle
  • 55 Answers
SOURCE: Who rebuilds ryobi 18 volt li ion batteries
Rebuilding the Lithium batteries is a waste of time and money. For starters the cells cost a minimum of $5 ea and a low power pack takes 5, so now you are in for $25 without doing any work. You can pick up packs on eBay for around $30 - $40 if you shop around. If you know what you are doing, you can strip cells from bad packs and test them to find good ones and then rebuild with those. It can be tricky and you may get mixed results.
Posted on Nov 11, 2014
Can you use 18v lithium battery in old 18v drill
Yes you can. On tools, 18 volts is 18 volts. Tools don't 'know' how the power is being created, either by Ni-Cad or Li-Ion means. Chargers are totally different. Most Li-Ion chargers can charge older Ni-Cad and some Ni-MH batteries but older Ni-Cad chargers will charge Li-Ion battery untill they overheat and sometimes start on fire because older chargers can't detect when the Li-Ion batteries are full.
Jan 14, 2013 | Black & Decker 18V Cordless Drill/Driver
Aug 23, 2012 | Ryobi Two 18V Lithium-Ion Batteries +...
I bougth reciprocating saw, model BJR 182Z and circle saw, BSS611Z while I was in the U.S.A.These tools use the 18 volt LXT Lithium-Ion battery BL 1830. I also bought this battery.However I am going to use...
Why can't you buy the 230 volt DC18RA charger in europe (amazon.europe country) and use it. I had the same issue yet i burned out the fuse in the 110 volt DC18RA charger because i plugged it into the wall just using an adaptor. Lesson learned. Therefore, my first solution was that i bought a converter from 220V-to 110 Volt. This showed me that my charger was done. So instead of getting another 110 volt charger sent here to Europe from Canada, I returned the converter and have on order a 230 volt input DC18RA charger from amazon.de which has the same 7.2-18V output. I have been told this will work yet the fear, and I don't know why, is that it will burn out the batteries in a year or so. It is difficult getting specific information from Makita, but I hope it all works out. Best of Luck for you
Dec 16, 2010 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Earlier this year, I purchased a new Ryobi P103 LI-ION 18 V/24 Wh battery powered blower. In the past week, the battery isn't holding a charge for more than 5 or so minutes. Any suggestions?
Try to discharge the batts to the full end.Then try charge them agian for at least 12 hrs.
Or contact them at https://register.ryobitools.com/contact_us/new
Nov 03, 2010 | Ryobi Multi-Volt Battery Charger
Do imported hxp battrys damage new zealand sold tools cheers
Well, it's highly unlikely as long as it is a HXP 18V Li-ion battery because pretty much all hitachi stuff is imported. The companies HQ is in Japan and so id the largest manufacturing plant. I hope this helps please rate this thank you
Mar 17, 2010 | Hitachi Hxp 18 Volt Li-ion Hammer...
Battery charges but is dead
The battery isn't any good. The charger is just going through it's regular steps. (I know how it is. I just bought two Ryobi 18 volt batteries for my Ryobi cordless drill, reciprocating saw, flashlight,
trim circular saw, combo set. $60 for two batteries)
Jul 15, 2009 | Ryobi Two 18V Lithium-Ion Batteries +...
Dewalt battery charger
You will need he correct charger, the 24V will destry a very expensive battery.
Sep 29, 2008 | Dewalt DW056 18 Volt Cordless Impact...
Ryobi Two  18V Lithium-Ion Batteries + Lithium-Ion Charger Upgrade Combo Pack Logo
585 people viewed this question
Top Ryobi Drills Experts
JOHN LAPIER
roeb
Are you a Ryobi Drill Expert? Answer questions, earn points and help others
