Changed the fuse in two places and pluged it in
The charging fuse on these is internal inside the battery box
1 carry out a continuity test in this blade fuse for open circuit
2 while open check battery volts is over 11 volt or scooter will drive=o/k if lower will need batteries replaced.
3.make sure your charger is the correct one for this scooter
as go go chargers conector are wired different .so a standard mobility charger wont charge these,as there will be no 24volt at pins 1 and 3 ,
