Saeco Royal Cappuccino Espresso Machine Logo
Vicki Gibbons Posted on Jan 15, 2015
I am trying to change my language back to English but the asterisk has a little square flashing over it preventing me from changing, please help
My Facebook is in another language change it back to English now
From your question it is understood that, default (English) language of your Facebook account has been unknowingly changed to some another language and you need a assistance to change it back again to English language. To help you change the Facebook language to English, please follow the instructions on the link given below:
http://www.wikihow.com/Change-the-Facebook-Site%27s-Viewing-Language
GuruAid.com
7" Zeepad tablet switched to Japanese somehow.
Hi!
To change the language back to English on your Zeepad tablet, try the following:
1) Tap the Settings icon (in some versions, it is a square icon with blue lines, in others, it looks like a small gear).
2) Scroll up and tap the "Language & input" icon (a square icon with the A letter).
3) Now, tap the "Language" selection (the topmost one)
4) Tap on "English (your country)" and then tap the arrow to go back.
Hope you may find this answer helpful!
Best regards,
Miguel L. Martins
Hi i was given a coffee machine by my frein the only thing is its in german can i change the language
Hi You need to change your language in the menu. Push and hold the menu button. When it changes in the window, use the up or down arrow button to move the asterisk (*) until you come to a window that has something like "lingua, or spreka", and then push the menu button again. Use the up arrow to scroll to "English". When you have the asterisk (*) in front of English, push the menu button again. You have selected English and then you can push the escape button to exit. Some machines have exit in the scroll bar, so it depends on your machine.
My wife somehow changed the language to Italian and it is no longer working. It says Descalcificacion Llenar Deposito when it is not in energy saving mode. I can't follow the instuction manual to change...
Hi
5helpful
Change the language on hp laserjet 4000 to english
For the LJ4000 to change the control panel language:
Turn off the printer.
On the front panel, hold down the SELECT key.
Turn the printer on, while continuing to hold the SELECT key.
When the Select Language message is displayed release the SELECT key.
Initializing will display on the control panel. After 5-7 seconds Language=English will display.
Press the VALUE key until the desired language is displayed.
Press the SELECT key and an asterisk will appear. The asterisk indicates that the printer has saved the new setting.
Press the GO key to display Ready in the language that was selected.
NOTE: If Select Language does not appear in the display, hold down the SELECT button until you hear the motors rotate, then release. Following printer initialization, the Language= menu will appear in the display.
hope it helps, if so do rate the solution
The language is is spanish i do i get it back to english
My professional royal saeco machine keeps saying in italian (Caric Circuito). Can someone please advise what the problem may be. Thanks!
Hi
1helpful
3answers
I changed the language and can't get it back to English. Can someone tell me how please????
I suggest you go to www.hp.com/support and search your 3380 printer. Find the owners manual and look in the index for instructions on how to change the language. If you have the owners manual ... well you could use that instead.
2helpful
I can not print, the error is: LANG=ENGLISH, please help
Changing the Control Panel Display Language
The default control panel display language is set for English.
Supported languages are: English, French, German, Italian,
Spanish, Finnish, Danish, Dutch, Swedish, Norwegian, Turkish,
Polish, and Portuguese. Follow these instructions to change the
display language.
1 Switch OFF the printer.
2 Press and hold Select while switching the printer ON until
SELECT LANGUAGE appears in the display.
3 After the power-on self test, LANG=ENGLISH appears. Press
[Value+/-] until the desired language appears in the display.
4 Press [Select] to save your choice. An asterisk (*)appears next
to the language to indicate it is now the default.
5 Press [Go]. The On Line indicator is lit, and display messages
are now in the language you selected.
2answers
I have an mtkbtdevice dual sim phone, when i access the internet all i get is little squares, how can i solve this problem
for example, go to facebook.com, and before you log in, on the left side of the screen you will see a little green window, again with the squares. try to scroll down, and you will see the languages which are offered!
Top Saeco Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Sulejman Sulejmani
Sulejman Sulejmani
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
