Question about York Fitness Z16 Treadmill
My treadmill goes through all the procedures but the start button wont operate its a York Z16
How do you replace a cracked running deck on a York Z16 treadmill ?
If you wish to get some details; check the site linked here. Pull up older posts.,,
http://electro-medical.blogspot.com/
Jul 24, 2016 | York Exercise & Fitness
Where to buy replacement fuses for z16
Often these devices use the same style fuses ("blade style") as modern cars. YOu may find what you need at the automotive section of WalMart.
Apr 23, 2014 | York Fitness Z16 Treadmill
York treadmill t-801la T780 platinum error code 1
see the comentary ERR1 indicates a speed issue. In this case, the motor speed as reported from the optic sensor differs
from the speed setting.
Analysis: Optic sensor signal issue -- Either the optic sensor signal is not right, or it is read incorrectly, or
the signal is not reaching the display.7099b61f-975c-463c-9361-522952e1c927.gif
Run the software calibration for easy diagnostic and fix it. God bless you
Jul 08, 2013 | Exercise & Fitness
Hi there i have a york treadmill and we moved house and when they were moving it it lost all this oil and now the automatic release button does not work so easily and i think it is starting to smell a bit...
you need to buy silicone 100% FOR LUBW the deck belt and rollers bearing.
You need to buy in any store for tredmills.RFemember LUBE the treadmills by each 5 hours of use.
God bless you
Nov 16, 2012 | Exercise & Fitness
I cannot get it to incline. It will say it goes from .5 to 10 and not incline at all
First perform an incline calibration. The procedure is outlined in your users manual.
It is a simple procedure. Insert the safety key and start the machine in motion. Press the incline up button. While the numbers are increasing remove the safety key.
Now reinstall the safety key, the machine should incline to maximum then lower back down to minimum.
Now you can operate the treadmill, the incline should work.
Jan 04, 2011 | Proform CrossTrainer Treadmill
The treadmill starts then after a few seconds it stops and a code L5 or LS comes up. the model is a york fitness z16
More likely LS= Loss Signal open the motor shroud on the motor their should be a cylindrical shape sensor (magnetic). Plug in treadmill and on the motor control board their should be a L E D (red or amber) by manually rotating the motor you should see that light flicker if it does sensor is good if not replace sensor. Next thing if sensor is good check motor brushes to see if they are mis-align or worn if worn less than 3/8" in length replace them
Mar 09, 2010 | Exercise & Fitness
I have a error reading of l5 or ls not too sure york fitness z16
The L5 message means that there is a problem with the speed setting switches. Some models have one set of speed adjusting stitches on the handlebar and another set on the console. One of them is defective and is causing the problem.
Dec 29, 2009 | York Exercise & Fitness
York t101 treadmill ls error
York treadmill T101 will not run has a error L5
May 11, 2009 | York Exercise & Fitness
York t500 treadmill model no:LQ6010 showing err07 when turned on
Error 7 is a Safety Key Error..
that's the red magnetic circular thingy on the console.
Simply secure the safety key in place and try it again
Jan 19, 2009 | York Barbell Home Use Fold-Up Treadmill
York Fitness Z16 Treadmill Logo
67 people viewed this question
Top York Fitness Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
Tom Chichester
ray gallant
ray gallant
Are you a York Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
