1. In settings try to turn up the volume.
2. Using a Q tip and some alcohol make sure the mouth speaker is clear.
3. Check with Telco to make sure the telephone line itself is working properly.
The problem with your phone is that the earpiece of your phone is faulty that is why you cannot hear anything when someone calls you or when you call someone.
All you need to do is to change the earpiece of your phone in other for people to hear you when you make calls or when you receive calls.
The earpiece of your phone is bad that is why you cannot hear anything when you make calls, change the earpiece of your phone as advice and you will see that you will hear when people call you.
This problem I've had myself But it will only solve the problem if your cell uses a sim card. When the sim cards go bad thats whats happens your hear them but they can't hear you or vice-versa.
Try taking a small needle and gently clearing out the mike hole near the end of the boom. Anything I am outside and sweating a lot mine will clog up and I have the same trouble until I clean it out and then it's fine. Do not insert the needle in very far, all you need is to clear the outside opening a bit.
