The sound for the radio totally cuts out , if I turn the power off and then power up after a few minutes the sound is back on the radio, when the sound cuts out on the radio and I switch to a cd the sound is fine and never cuts out. The frequency of this is steadily increasing as I have only had the unit 2 weeks and the radio sound lasts only 5 to 7 minutes now. Dealing with eonon is fruitless as their comprehension of English is almost nil. Please help me troubleshoot this problem.
SOURCE: hisense air conditioner
-If both compressor and fan motor starts and stop, thermostat is the defect.
- If only the compressor check for your outlet no sign of discoloration, check the voltage if normal, check the defective overload protector of the compressor it its external, or compressor itself is defective
SOURCE: Jensen VM9311/ UV7i wont turn on!!?
Yo, I've got the perfect solution to your problem. Pull out the head unit from your dash. Then, remove the wiring harness carefully from the unit. Now, push in the yellow power wire (even jiggle it a little) making sure it's tightly snug the small port of the wiring harness. Then, plug the harness back into the unit and try turning it on. I've found that the wires come lose easily on this unit. hit me back up at [email protected].
SOURCE: eonon 837 car multimedia.
IF THE RESET FUNCTION DOESN'T WORK, USUALLY A LITTLE PIN JOLE SOME WHERE ON OR UNDER THE FACE PLATE, USE A PAPER CLIP TO TRY AND RESET, IF THIS DOESN'T WORK RETURN THE UNIT WHERE U BROUGHT IT IT MAY BE A MANUFACTURE DEFECT
SOURCE: Mitsubishi VS-6071 60" Rear Projection TV Problem
can you give me the number of the manufacture of a 60in mitsubishi VS-60707
SOURCE: how do i by pass the parking brake switch on the eonon e686
Just connect it to black (ground) wire from car connection.
