you can start by looking for a speaker adapter on amazon. To ensure compatibility with your samsung tv, you can provide the specific model number to the seller so that they can check on their end. And you can also call the manufacturer of the product to ask them to verify the compatibility with your tv as well.
there are two tests to chk which is bad,wether it is the control switch or the elemnt.disconnect the power to stove and open the top and disonnect the wires from elemnt and chks the continuity of the elemnt coil with a multimeter.if the meter does not read continuity then elemnt is bad.to confirm this connect the wires back to the elemnt and plug the unit to power, turn on the switch to high position and read the voltage coming to elemnt.it should be 240 volts.if u read that voltage, then for sure element is bad.if every thing is opposite to this then it is the control switch which is bad.
if the hs ind light does not turn off then that particular heating elemnt needs to be replaced.heat sensor is built in the elemnt.when elemnt is turned off and it cools down it makes a switch to open and inturn ind light turns off.but sometimes thst gets stuck and light remains on.but do not worry abt element,it remains off,its just that indicator light that remains on.
youd be better to leave the old elemnt in tillits replaced, the wire leading to the elemnt is ALWAYS live, even when not on there is ALWAYS power to the elemnt wire
Good Day, GLENN;
I assume that IHVT was arcing from the side, and the audio is from the TV and not stereo? Or was it the high voltage splitter? Was it plug in or soldered IN? It sounds like you may have bridged a solder joint, unplugged something by accident or something else? Double check your work first of all. Do you still get high voltage? You may poor part. Good Luck, big IRISH.
