I have held down temp button on remote for 2-5 seconds with no change. have power ,temp, +,-, time buttons only on remote.
SOURCE: comfort zone infrared heater
Hello all , just push and hold the two buttons on the right for 3 seconds and it will reset. Joe
SOURCE: change temperature from Celsius to Fahrenheit on a comfort zone h
To change your heater display from Celsius to Fahrenheit: press and hold the "down" button and the "enter" buttons simultaneously for 5 seconds and release. - VS
SOURCE: I have a comfort zone
Unless you want a new house, stop using that heater immediately. There are severe internal electric problems with your heater. Since it's already 3 years old, I'm not sure it's worth trying to repair. With what you described, I'm surprised it didn't trip one of you circuit breakers.
Be safe, Don't continue to try to use this heater.
SOURCE: Where do I refill and
Here is a tip that I wrote that will help you to understand about oil filled radiator heaters....
Oil Filled Radiator Heater Leaking
heatman101
SOURCE: Comfort Zone CZ 1500 A04 CONTINUES TO COME ON
The AO4 is a board used by Earthwise on the Comfort Zone Heater. The reading is the board being used. If the heater just gives that reading it may need to be reset. This can be done by pressing up, down and enter at the same time. If this does not work unplug and try it again. Hope this helps
