Locks & Locksmithing Logo
a
ashwani Deva Posted on Jan 13, 2015
Battery is removed and the keys are inside - Locks & Locksmithing
eug1
Level 1:
New Friend:
  • Contributor 10 Answers
  • Posted on Jan 13, 2015
eug1
Contributor
Level 1:
New Friend:
Answers
10
Questions
0
Helped
13098
Points
36
Is it a safe with an electronic lock? The safe usually comes with a key that you should keep outside the safe not in it exactly for this flat battery scenario that you're in. The battery box for your electric lock is usually on the inside of the safe so you need the key to open the lock. You can force it open, check this video https://www.youtube.com/watch?v=aqC9V7SDKdQ
2answers
Fob still won't work after new battery and nothing wrong with the contact inside, do not hae original code for the Kia sportage 1998 so what is the next best thing ,to do?
When replacing the key fob battery there is no reprogramming required! If the key fob was working prior to the battery replacement then it would point to the contacts not being correct! Remove key fob battery and start again!
How to release a smart key from ignition in a Mercedes Benz 2002 e430
Either the battery inside the fob key is flat.If it works the door locks etc then it is not the fob key battery, If your key/s have been dropped it could be a broken wire on the solenoid inside if so carefully disassemble the fob key and gently remove the circuit board solder the wire back down re-assemble the fob key & try that if this doesn't work or it is not the case then contact the dealer for further assistance.
I have a 1999 Chrysler circus it will not start and the key is stuck in the ignition checked all fuse their all good tried to jump start it all lights come on but won't start
Battery is dead, replace battery and have proper amp to ignition and should be able to start and remove key, somewhere inside column there should be a switch that you should be able to press and remove key as well.
3helpful
3answers
Can't remove key from ignition. battery is dead
If the battery is dead, the ignition keys will not release from the ignition. If there is no signal from the transmission shifter that it's in park since the battery is dead, then the ignition lock will not release the keys.  After charging the battery or jumping the blazer to start it and the key's still will not release, try this.
There is a "plunger" as part if the ignition. Under the steering wheel there is a small removable cap that you can take off and put a small screw driver up into and press the plunger in and it will release the key. Good luck and hope this helps, Keep me posted be glad to help.
Does the remote key for a 2001 mercedez s500 have a replaceable battery?
There are (2) batteries (CR2025) inside the remote key which can be replaced. You remove the spare key and the top of the remote can be pried open.
3helpful
2answers
Key fob does not unlock the doors
remove the keyring from the fob open it and replace the watch battery in it
The number 1 button will not press
Key override
If your electronic lock fails or you do not have any codes
available, you may use a key override to access this unit.
1. Remove the battery cover, disconnect and remove the
battery holder.
2. Insert the skeleton key (second set of keys provided)
into the key hole inside the opening for the battery.
3. Turn the key to the right.
4. Turn the four-bitted key to the right.
5. Open the door.
You can download the user manual here:
http://www.sentrysafe.com/pdfs/OwnersManuals/172967.pdf
Top Locks & Locksmithing Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
