When the error code came up, I bought a new toner and the code still appears. It keeps saying that the toner door is open but I can't find anything wrong.
SOURCE: canon laser class 2060p super g3 fax machine
The error keeps flashing and the machine will not work. The error reads, "check cover/cart". We put the cartridge in and out about 10 times and the same error message keeps flashing. the fax machine is still not working. Help!
SOURCE: canon super g3 image class d880
E000 means your fuser section is having problems.sometimes you can reset but may need to replace fuser unit.
SOURCE: i have a canon super
I pulled the plug on it, counted to 10, and plugged back in. So far the first fax worked fine. We'll see if this takes care of the problem.
SOURCE: the paper feeder of my canon super g3 jams every time
Yes, there is an easy solution, possibly. Mainly because you say it may do a single job, and then it keeps jamming. Do you see the second sheet jamming in when it is not called for? Anyhow, you may try cleaning the rollers, all of them, like I did here: http://annoyances-resolved.blogspot.com/2009/09/paper-jam-buy-new-laser-printer.html This completely solved my problem of persistent paper jams.
