Amana NTW4501XQ 3.4 cu. ft. top load washer with spreckle porcelain ba Logo
Alice Ryan Posted on Jan 12, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
HAVE DONE TEST ALL LIGHT'S BLINK / FLASH GREEN EXCEPT LID LOCK LIGHT IT STAY'S OFF
NEW ACTUATOR TRIED TO RECALIBRATE MACHINE ALSO
David Smith
Level 2:
Scholar:
  • Expert 120 Answers
  • Posted on Feb 26, 2015
David Smith
Expert
Level 2:
Scholar:
Answers
120
Questions
Helped
20259
Points
316
Sounds like the lid switch itself is bad or the control board is not recognizing the lid switch.
Maytag Cent. Washer MVWC400XW3, stuck on SENSING and LID LOCK I replaced the Door Lock and Actuator - still getting the same results as I did before I made any replacments
Unfortunately that error code is for a stuck keypad. It's like the button is being held down constantly. You can replace the control panel or clear error codes and try again, also you need to calibrate this washer after changing parts. If you open the lid and reach between the tub and cabinet at the front left corner, you will find the tech manual.
2answers
Whirlpool he washer-lid lock light flashing and lid locked. reset by using start/pause/ lock button. start washer-light comes on/sensing begins light starts flashing again and washer stops operating
LID LOCK LIGHT STAYS ON NO START:
Usually either the lid lock mechanism, the lid lock actuator or the board is the culprit even a disconnected capacitor.
MACHINES SAIDS SENSING
When the START button is pressed, the washer will first perform a self-test on the lid lock mechanism. You will hear a click, the basket will make a slight turn, and the lid will unlock briefly before locking again. Once the lid has locked the second time, the washer
will slowly spin the dry load to estimate the load size, and begin adding water. The washer will then move the load briefly, pause to allow water to soak in to the load, and resume adding water. This process may repeat until the correct amount of water has been
added for the load. You may also hear water flowing through the dispenser, adding detergent to the load.
NOTE: The sensing light may also come on during the Soak and Wash portions of the cycle. This is normal.
Try unplugging the cord a couple of times. See what happens then try going into diagnostic error codes, see what codes are shown. To pin point where the problem is. if you have no display to read the fault codes. Your main control board may be the issue.
Next, while in Manual diagnostics, try to get the unit to spin; if the motor hums for a split second and then shuts down with the lid lock blinking; go back into diagnostic codes and look for shifter or speed sensor errors.
This is proof that the shifter/sensor actuator assembly is the issue because the optical sensor is not reading the motor speed.
I suggest unplug the washer and check the wire connections on the switch. If a meter is available then you can check the resistance (ohms) of the lock motor.
Note: After performing the manual test and the lid lock works perfectly, or at least as it is supposed to. You can eliminate that as the problem.If the lock worked in the manual test but doesn't in an actual cycle then I suspect the control board is at fault.
A safety feature found on front load washing machine is the door switch and the door lock and strike. On most models, the door switch must be closed and the door lock must be activated before the washer will start. The switch is normally located in the door frame of the washing machine, but may also be part of the door lock assembly. Inspect the strike to make sure that it engages the door lock assembly and that the door remains closed. To check the door switch for continuity with a multi-meter, you will need to disconnect the power and remove the front panel.
The lid switch on a top load washing machine is a safety device designed to prevent the motor circuit from operating when the lOn some models, the water inlet valve circuit is controlled as well. If the lid switch fails, the washer may not start. The lid switch is normally located beneath the main top with a projection on the lid or a pin attached to the lid that will actuate the switch when the lid is closed. Verify that the switch is being activated mechanically and that any levers or actuators are not damaged or sticking. If the switch is being activated but there is no power being supplied to the motor or water valve circuits, then the switch may be defective
The start switch on some top load washers is often part of the timer and is activated by pulling out on the timer knob. Although not normally available as a separate part, the switch can be tested for continuity with a multi-meter. You will need to remove power from the appliance and then locate the correct timer contacts as noted on the wiring diagram. On some electronic controlled models, the start switch is a momentary contact type switch located on the control console. You can test this switch for continuity with a multi-meter when the push button is held in
God is good and that's why I give free advice.
Blinking lid locked light and green sensor light on machine won't start cycle
The good ol' Whirlpool Lid Lock Flashing Light Problem - ApplianceBlog
www.applianceblog.com/.../42456-The-good-ol-Whirlpool-Lid-Lock-Fl...
Dec 11, 2013 - 10 posts - ‎3 authors
Red Lid Lock light flashing intermittently when you try to start a cycle. ... I'm going to post what SENSING does first, then you will need to locate your tech. ... start with thelid lock on and blinking, or the unit will not start and spin. FIXED Sense light on light humming noise won't start ...
Aug 9, 2015
Whirlpool WTW4950XW not working
Nov 2, 2013
Stacked GE washer/dryer lights Blinking doeent start at ...
Feb 20, 2012
More results from www.applianceblog.com
Washer Sensing led (Green) on with the lid locking led (Red ...
www.shopyourway.com > Manage My Life > Questions
... this: Sensing led (Green) on, the lid locking led (Red) blinking with a clicking noise ... red led light goes off green led light stays on and the washer does not start.
Amana Washer NTW4501XQ0. I have replaced the lid switch, and the timer. The washer still will not run thru an entire cycle. What should I try next
You can try recalibrating unit. With your dial setting at the 12 o'clock position on the timer, you want to do these steps within 7 seconds. Turn timer knob left one time, 3 rights, one left, one right.
Then you will see all the lights blink. ( no time constraints after you see lights blink) Turn the knob 4 clicks to the right, then push the start button. Let it run until you hear the lid unlock and you see the done light lit up. When you replaced the timer, you needed to recalibrate the unit.
WASHER ... COMES ON GREEN SENSING LIGHT STAYS ON START'S TO FILL CLICK'S OFF RED DOOR LIGHT LOCK LIGHT COMES ON STAY'S BLINKING
Thank you first person that has provided a model number sounds like you already changed the lid lock assembly if you did you know how to get the top up inside the front panel is a tech sheet it will tell you how to place the unit into diagnostic and read the lights for an error code recheck your connection at the control board a flashing lid lock would should give and F5E1 or F5E2 error code also check the alinement of the tab on the lid where it goes into the lock assembly should be a smooth transition
DID AUTO TEST MODE RAN THRU CLYCLE SOLID GREEN DONE LIGHT IS ON NO OTHER LIGHT'S CAME ON
lift the lid. done light indicates that test cycle is complete. If you are getting done light only, all the time, control board is not recognizing that lid was lifted, allowing it to go back to normal operational mode. check lid switch and control board.
HOW CAN I DO A LID LOCK TEST
Place unit in diagnostic turn knob till rinse and spin are lit press the start button lights should go out press start again the lid should lock light on press again unlock and off
1helpful
Ge washer gcrh410
6helpful
6answers
The lid lock light won't stop blinking.
LID LOCK FAULT
Fault is displayed if Lid Lock has not moved into locked position or motor cannot be powered.
Lid is not closed completely due to interference.
Check for lock interference with lock striker.
Wash media buildup (detergent, lint, etc.) is preventing the lock mechanism from sliding.
Main control detects open lid switch when attempting to lock.
Main control cannot determine if lid lock is in a locked state.
Perform the following checks if the washer does not lock (or unlock).
1. Perform the Lid Lock test under Manual Test Mode on page 9. The following steps assume that this step was unsuccessful.
2. Check lid lock mechanism for obstruction or binding. Repair as necessary.
Top Amana Washing Machines Experts
Virgil Watts
ZJ Limited
ZJ Limited
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
