No sound when playing back from TV recordings on the hard drive.
This problem has occurred overnight. Can play back from hard drive recordings from several days ago and get sound. Sound is OK from playing DVDs. Picture is good in all cases.
To use the PVR record function on Bauhn TV's you MUST "Format" your Hard Drive or USB device as "FAT32" using the formatting options built into and supplied with the said Bauhn TV. There have been relatively recent changes made to the FAT32 formatting system which now allows you to format very large drives to FAT32. These changes were made after requests from manufacturers like Bauhn so that they could incorporate PVR functions into the TV set itself. I run a 1.5 Terabyte Drive with my Bauhn and it performs beautifully. I won't say that I hope this helps because "I know it will" :) Cheers....... PS: The resultant files will have the extension SQ rather then MGP of FLV etc etc. I can't get these SQ files to play back on my PC albeit that they do play back perfectly on the Bauhn TV. If anyone knows of a program/player that will allow playback of SQ files on PC's then it would be great if you could post it up here.
Hi, Mary with Dish Network Customer Service. Since the DVR is the only thing having the freezing issue, it sounds like it maybe a hard drive issue. I would recommend resetting the receiver. Unplug it from the power supply for 10 seconds and then let the receiver reboot itself. If you are still having this issue, I would recommend calling Dish Network and we will need to replace the receiver. Hard Drive issues do not resolve themselves and only get worse over time. Please let me know if I can be of further assistance.
Hello, my name is Daniel Busa with Dish Network customer service, I reviewed your question I have seen this before, t sounds like its possibly a bad hard drive try unplugging your reciever for ten seconds if it's persisting then we may need to replace it.
Hello, Daniel Busa with Dish Network's customer service department. This issue is called corrupted recordings, which can be a bad hard drive or poor signal try deleting all of the bad recordings and unplugging the receiver for ten seconds.
I cannot help with your problem but unfortunately the same thing has just happened to me this morning. I woke up and every recording is apparently gone, but I cannot record because it says there is no room on the HDD and for me to delete titles. Can anyone help!?
