Kenwood KVT-514 Car DVD Player Logo
Anonymous Posted on Jan 11, 2015
HOW DO I REPLACE THE TOUCH PANEL IN A KENWOOD KVT 514
Lcd panel ok but the touch panel. need to install touch panel
5 Related Answers
Anonymous
  • 10 Answers
  • Posted on Oct 07, 2008
SOURCE: wiring diagram kenwood kvt 810
go to kenwoods websight and the have downloadable install manuals
Anonymous
  • Posted on Jun 08, 2009
SOURCE: I sent a Kenwood KVT-514 to my niece in Europe. I
no you must send her us dvds
Anonymous
  • Posted on Dec 16, 2009
SOURCE: kenwood kvt-815 dvd touch screen not working
did you ever find a solution for this problem, I am currently experiencing the same thing
Anonymous
  • Posted on Sep 16, 2010
SOURCE: kenwood kvt 514 can't turn on the sub
in the main option menu for choosing tuner dvd video etc. scroll down one and youll see "standby" put that on then scroll through the options and turn on the sub
Anonymous
  • 18 Answers
  • Posted on Apr 02, 2011
SOURCE: How to pair your phone to the bluetooth on th
Go into your Setup menu and scroll down to bluetooth settings.
From here you should see a screen that says "HFP connect device", "A2DP connect device" and "Receiver pin code".
Press the "Set" button to the right side of "A2DP" and it should bring you to another screen that says Pair device.
Go onto your phone settings and make sure you have your bluetooth setting on your phone set to "make discoverable"
Press the search button on the Kenwood unit on the right side and it will start scanning for available devices in the vicinity
Also press the Search button on your phone so it also starts scanning.
Next you should get a message on both your phone that shows the Kvt-514 and also a message on the Kenwood that shows either the model of your phone or your "nickname" (if you named your phone)
Select the Kvt-514 on your phone and it will prompt you for the pin code that was on the first bluetooth setup screen...most likely 1111 (you can also set a different pin code using the "set" button to the right side of the "Receiver Pin Code" on the first bluetooth setup screen)
Enter the Pin code and select "Pair" on your phone.
You should get a confirmation on both the Kvt-514 and your phone that they are connected and you're good to go.
Have a kenwood kvt-514 but don't have the rca cables to connect to the amp how do i connect the deck to the amp
Ozzie my car was burglarized and had my code to my kenwood owners manual now can’t turn my kenwood kvt 514 unit back on can you please help
Touch Panel Broken
there is a guy on ebay that fixed mine Trbilea1999
he repaired my touch screen and updated all the software
Help me crack the security code on my kenwood KVT-514 DVD car stereo????
Here's a video tank daWG suggested as a solution to your problem from YouTube:
how to unlock code kenwood stereo.3gp
1helpful
How can I update tha software for keenwood KVT-514
Try this link. http://www.helpowl.com/p/Kenwood/KVT-514/Research/53126?search=Kenwood+Kvt-514+Update&x=79&y=17
Codigo de seguridad de kenwood kvt-514
buenas,, hace tiempo compre un repro kenwood kvt-514 y al encenderlo me sale en la pantalla CODE SET y no tengo el codigo,, hay manera de desbloquearlo sin el codigo que me solicita...???
I forgot my security code for my kenwood kvt-514
Hello
To deactivate the security code,
Display the Security Code Setup Screen.
Start to cancel a registrationof the security code.
Enter a new security code. Input a four digit number as security code.
Register your security code.
Now the previous security code is cleared. OK.
5helpful
How to unlock code for kenwood kvt-514
Did anyone ever figure this out? I need to know also
2answers
Kenwood kvt m700 touch screen problems
You don't need a code, it's unlocked by the remote that came with the unit (small purple one)
3helpful
2answers
Wiring diagram kenwood kvt 810
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
