Lights stayed on after I closed the freezer. The fridge started to beep for a while this morning, and then lights in both the fridge and freezer just shut off. Cleaned out the freezer, closed the door, and light still stays on. Freezer is closed fully, so I can't figure out what the problem is.
I am curious how you know it is on unless you get inside. Some have magnet switches that will not cycle until the gasket seals.
The small space between the door of the freezer and the door of the fridge is white, so I could see the light from the freezer kind of glowing through that. The freezer door seems to be fully closed and sealed like it would be normally, but apparently something is wrong... Is there something I can do to try to fix this?
