Whirlpool super capacity Model WT47-201 will fill with water and agitate however it does not move from one cycle to the next. I have to move the dial manually to get it to move from washing to drain
Model WT47-201 The dial is not moving from one cycle to the next. eg. from wash to drain, rinse etc. I have to do this manually
hum either a bad timer sticking the point contacts close. have u tried this in all cycles? and possibly a motor with bad windings not enough power to run agitation? try running in mild or gentle and see what happens? I was tempted to say the cam dogs in agitator but they dont work then stop then work, when they go out they go out.
My whirlpool heavy duty 2 speed 7 cycle washer machine stopped working, It fills up and aggitates for the first cycle then when it should drain and spin it doesnt drain nor spin
Hello there: When the cycle doesn't advance, or it takes a very long time to complete a cycle. !st, check the timer to see if it is working properly if not replace it ' next make sure that you are getting cold water and it is getting adequate pressure.:here is how to check the timer . if your washing machine fills with
water and begins agitating, but the timer never advances--or if the
washer is in a spin cycle and the timer won't advance. Then you need to
replace the timer. It may be a cold-water supply problem, if the washing
machine fills with water, agitates, drains, and spins, but then doesn't
fill with rinse water. See There's no cold water. Ok? Hope this is very helpful for you Best regards Michael
Sounds like what you are describing is the timer on the dial is not activating the next cycle. Timers are usually the problem when the cycles do not complete there cycle
