OK-- are you talking about simply connecting one computer to a home network, or setting up wireless network in general? If there is a wireless adapter in the PC and you already have a wireless network, the adapter will list all the networks in your proximity, and you choose yours. I can go into greater detail with that when I see your response.
Thanks
SOURCE: Acer Aspire T180 PC Desktop
if you have windows 98 boot disk put that in, the firt thing you do is to go to f-disk and change the partions in it, then format c: drive. take out disk in A drive put in New windows XP CD and restart. the disk will run and install itself. and thats it. right now your partions are set to read only windows 95, 98, there are 2 options to choose from I belive the one you need is 32.
SOURCE: Windows Xp Home edition Installation
Hi tross202;
Is that an original XP home edition installer? You may try another cd installer if you can secure one.
SOURCE: i have reinstalled windows xp
Chipset (http://www.sharpsystems.com/kb/PC/PC...er/CHIPSET.zip)
Display (http://www.sharpsystems.com/kb/PC/PC...er/display.zip)
LAN (http://www.sharpsystems.com/kb/PC/PC...driver/LAN.zip)
Modem (http://www.sharpsystems.com/kb/PC/PC...iver/MODEM.zip)
SpeedStep (http://www.sharpsystems.com/kb/PC/PC...r/SPEEDSTP.zip)
Sound (http://www.sharpsystems.com/kb/PC/PC...iver/SOUND.zip)
Touchpad (http://www.sharpsystems.com/kb/PC/PC...r/TOUCHPAD.zip)
Wireless (http://www.sharpsystems.com/kb/PC/PC...river/WLAN.zip)
Try this
SOURCE: Laptop Cannot Find Home Wireless Network
Try logging into the router with your desktop hard-wired and find the 25-digit passcode and use that to log on to the wireless network with the laptop. If not, then check if connection is good by hard-wiring the router to the laptop. Let me know what happens or if you have solved the problem.
SOURCE: troubleshooting wireless home network using
To Configure a Wireless Connection in Windows XP, Follow the Instructions Outlined Below.
Note: The hexadecimal key and wireless network name should already be set up on the 2Wire device. Use the key that you set up on the 2Wire device.
