SOURCE: hobart 60 quart mixer
the motor protection board is doing its job.you should only use 1st speed to mix pizza dough.im a hobart technician and service these mixers all the time.let me know
SOURCE: Hobart 20 quart mixer
Hi im a service tech for hobart.I cant give service manuals out because i could lose my job but i can step you thru your problem with the mixer,let me know.
SOURCE: how to change oil in 20 quart hobart mixer and the
on a a200 there is no oil. this mixer requiers grease. if mixer is leaking oil it is because the grease is broken down .you have to pull tpo cover off mixer remove trans. parts clean out old grease clean all trans. parts reassemble put top cover back on .then make sure mixer runs in all 3-speeds before putting 1.5 cans of -47grease back in grease can be bought @any hobart office
SOURCE: What type of oil does a Hobart 60 quart mixer use?
a H-600 takes part#102973-71, thehl600 takesthe same just less. dont for get to vote tks. monomoy
SOURCE: I have an old 60 qt hobart mixer. What type and
Mobilgear 634
128 FL OZ or fill it to the line in the sight glass.
