Vtech Digital Cordless Telephone VT-2568 Logo
d
dante di pentima Posted on Jan 10, 2015
How do i put ringer off my phone - Vtech Digital Cordless Telephone VT-2568
We have two 6.0 phones. How do we put the ringer on silent on one and not the other?
Choose from four ringer volume settings (off, low, medium,
and high). With the phone in standby, press or UP or DOWN symbols . The display shows the current volume level and the handset sounds the ringer at that level. Use UP to make the ringer
volume louder or DOWN symbol to make it softer or turn it completely off.
Uniden Model EX 14560 Ringer off How to put ringer on
Here some solutions for your problem + a link to the user manual.
**Selecting the Ring Tone and Volume
Your phone has five different ringer tone/volume combinations you can choose from.
To select the ringer:
1) With the phone in standby, press [vol/ / ] or [vol/ / ].
2) The phone will sound the different ring tones at different volumes. To turn the ringer
off, select RINGER OFF.
3) When the phone sounds the ring tone and volume you wish to use, press [end].
**Temporarily Mute Ringer
If the handset is off the base while an incoming call is ringing, simply press [end] to mute
the incoming ring. The ringer will sound with the next incoming call.
Note: You can only mute the handset ringer if the handset is off the base when the phone starts
ringing.
Adjusting the Earpiece.
**Here is also a link to the phone manual http://www.uniden.com/pdf/EXI4561om.pdf
3helpful
2answers
RInger off
the ringer is always on except you must have put it on vibration.check the stting of you phone,go to the profile and edit the ringer.
1helpful
How to put my lf rumour on a silent mode?
are you serious? on the side of the phone is the volume control. turn it all the way down till it says silent or you can go to settings, sounds, ringer, ringer volume and from there put it on silent.
Jul 22, 2009 • Cell Phones
2answers
The ringer won't stop ringer
remove the battery leave it out for about 5 mins and put it back in
Music for my ringer?
No, there is nothing for the LG, basically you have to buy the songs if you want them as a ringer.
10helpful
3answers
Ringer off, need to re-install ringer. volume control does not put ringer back on
To turn your ringer back on, you do the following. For your handset, you push Menu, scroll to ringer settings, then push select, Press select again for ringer volume, then scroll up to turn on and increase the ringer volume. Then press Save once its at the desired volume. To change your base ringer, while it is not in use, push the ringer up button until you hear the desired setting. That should fix your problems.
MP3 in ringner
Not possible. They have it made so you have to buy ringers. Your only solution is to somehow convert an MP3 file into a .3g2 file (video), and have it under 512KB, and under 30 seconds long, and use it as a video ringer.
Top Vtech Lands Phones Experts
Grand Canyon Tech
Grand Canyon Tech
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
