Are you using the a/c? If so it is probably a clogged a/c drain. Will find it under vehicle near firewall. Small rubber hose. Run a clothes hanger up it or compressed air.
Check the shift interlock, it is designed to keep the vehical in park until the brake is depressed. Try turning the steering wheel (both ways if necessary) as you turn key to remove it
On 05+ Trail Blazer, the fuel filter is integral with the fuel pump inside
of the fuel tank. It is a non-serviceable part. On 02-04s, the filter is
on the drivers side frame rail at about the B-pillar. If your trail Blazer is a late 04 which means that it was build close to the 05 Trail Blazer, you may have a non serviceable fuel filter. Good luck and check under your Trail Blazer or look at your manufactured date sticker on the door which would help you indicate if your 04 is a early Trail Blazer and you'll have the fuel filter on the inside frame rail under the driver's door.
