It works fine as long as it`s plugged in. But it wont charge, the charging light will not go on. I don`t have a remote for it.
SOURCE: supersonic SC-299TDVD
Battery back needs to be connected to the DVD player when charging. connect the batter pack to player. Run the DC/out from the battery pack to the DC/in in the player. plug the charger into the wall.
if that does not work, you have a bad battery
SOURCE: Dell latitude D600 battery charge light flashing
You have a ground fault issue in the DC JACK.
There are escentially 4 circuits in the jack and one is not making contact.
1: Negative Charge circuit (outter ring)
2: Negative Run circuit (outter ring)
3 Positive (Inner Ring)
4: Signal (center pin)
I believe the negative charge circuit (outter ring) is not making contact internally. Typically what happens on that model DC Jack is the tension contact metal becomes fatigued, and does not touch the outter ring.
This could come from Heat causing early fatigue of the metal.
Or normal wear, the metal has simply worn out from regular insert/removal.
Don't forget to rate suggestions
SOURCE: Fuji Fine Pix Z5 battery won't charge
I had the same problem!! Try flipping the battery around and then charging it. It worked for me! Hope this helps!
I looked up this question with the same problem and while the battery was placed in with the right side in, the three metal tabs weren't on the right side with the three metal chargers- so I had to spin it around the other way...i hope i'm explaining this right...now it's charging! I am so glad. This camera is excellent.
That usually indicates battery is beginning to go bad. Eventually it will not hold a charge and will need to be replaced.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
