Charging & Starting Systems for Lincoln Zephyr Logo
j
jennifer Posted on Jan 09, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I started my zephyr, while it was warming up, the RPM dropped..sounded like and "thump" or like the car downshifted really hard, BUT IT WAS NOT IN GEAR, it was still warming up, the "wrench" light cam
All i did was start the car, while waiting for it to warm up, rpm dropped and now wont start
mbarre
Level 3:
  • Lincoln Master 937 Answers
  • Posted on Jan 16, 2015
mbarre
Lincoln Master
Level 3:
Answers
937
Questions
Helped
311197
Points
5626
Jennifer,
Best advice is to get the codes and that will tell you why the check engine light is on.
93 mustang 50v8 engine what causes engine to quit running at high rpm then restarts as rpm falls
So is this the only issue your having? Is the stang hard to start cold or warm? Hard to say with what youve asked....Is your TFI newer how about your Dizzy?
Where is lincoln zephyr throttle control
You need to have the systems control computer scanned for fault codes, guessing isn't really an option here.
1helpful
Hard to select gears toyota coaster downshift to third and hard to get 5th
sounds like the synchronizer in the transmission is worn.
1989 pathfinder transmission 3spd w/ overdrive works great when first started, then downshifting starts way early, started after alternater wentbad
Do you mean upshifting starts way early? Going from 2nd to 3rd in other words?
Ireally don't know your transmission,but the alternator problem might've possibly spiked and hurt your shifting solenoids in the ******. don-ohio (:^)
Backfire through carb
Sound like your timings off
My truck is idlin low
my truck runs about the same but if the truck is having a hard time staying running maybe the computer in the truck is going out and giving the wrong messages to the truck to run right
1994 BMW 540i does quick, short, unexpected downshifts
Dear sea_lion42, Friday 2-20-2009 11:22pm EST (USA)
Check your transmission fluid which is usually done with the engine warm and running!
If the tran fluid is low add some Lucas Trans Fluid from your local auto parts store!
The knock makes me believe your low on trans fluid!
jack
Top Lincoln Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
john h
Are you a Lincoln Vehicle Part and Accessory Expert? Answer questions, earn points and help others
