Pride Jazzy 614 Hd JAZZY 614HD Logo
Mechelle Tarrant Posted on Jan 09, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Have a jazzy pride 614 and it is hard to get it to back up and it
Rob Hill
Level 3:
  • Pride Master 1,480 Answers
  • Posted on Jan 10, 2015
Rob Hill
Pride Master
Level 3:
Answers
1480
Questions
0
Helped
518109
Points
3838
Hi, where are you please ? ... there can be number of reasons for this, the most common...
1. the reverse logic of the controller is breaking down..
2. the joystick mech ...
Regards
Rob
www.gewizrepairs.co.uk
Why won't the jazzy chair turn back on. I only get running lights on the controller
Is the controller locked? Does the controller beep? The best way to troubleshoot the problem is to go up on Jazzy's website and download the service manual
1helpful
Jazzy 614 HD. Motor runs but the wheel does not turn
hi T. Phelps, sounds like the coupler situated between the motor and gearbox is broken etc.
Regards
Rob
Speed fluctuating on controller. goes from slow to fast without me touching controller on pride jazzy 614 hd battery powered chair
Your controller is dirty. Unfortunately, the unit is sealed and you therefore can do other than replace the unit. I suggest monster scooter parts at Jazzy 614 HD Parts The cost is high at $377.00. If you were really into fixing electronics it is possible to take the unit apart and clean the joystick, but that is a stop gap measure until you get your new joystick. Let me know if you need instructions on tearing the joystick apart and I will help if I can.
What does a jazzy 614 power chair 9 flashing wrenches need?
hi, that is the code for a brake fault , check the wiring to the brakes located on top of the motors...
Regards
Rob
Flash code list #7
Go to Pride's website to download the service manual. It has more information than the owner's manual does.
Lights on controller flashing
You can get the service manual from Pride's website. It will tell you what the flashes mean and how to fix it.
My jazzy pride 614 wont go anywhere when i push the joystick forword a yellow light flashes but its yo hard to see
if it can be pushed then the free wheel locking lever is needing to be put in the locking position
I have a Jazzy 614 HD scooter. The right tire seems to skip and not get traction
The newer Pride Jazzy and Quantum series are known for motor failure where the wires become broken inside the wire insulation at the wire entrance to the motor housing - so the break can not be seen. It starts as a shutter and is intermittent.
(The motor wire's gauge / strand count is too low for the repeated flexing when the motor articulates during acceleration and deceleration)
Eventually the break completely and you are stuck.
If the chair is less than 18 months old take it back to the dealer and demand a warranty replacement. If they don't fix it then contact your State Attorney General regarding elder and disabled abuse. Seriously!
7helpful
Blinking yellow wrench light on pride jazzy 614 HD
Your version has a Dynamic Controls model controller and joystick.
Unplug the charger and engage the motor/brake lever so the chair is no longer in free-wheel mode (con't push by hand)
Turn the chair off, wait 5 seconds, turn the chair back.
If chair still does not run and your wrench is flashing you have a problem. Count the wrench flashes - the flash count indicates the error detected. 3, 4, 5, and 6 flashes indicate and error with the motors.
3=Left motor fault
4=Right motor fault
5=Left brake fault (may not be engaged)
6=Right brake fault (may not be engaged)
Any other fault code usually means the electronics or wiring is bad and not worth fixing.
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
