Lexmark E360DN LASER PRINTER  N Laser Printers Feeder Tray Logo
Anonymous Posted on Jan 09, 2015
How to replace Lexmark e360 pick-up arm - Lexmark E360DN LASER PRINTER N Laser Printers Feeder Tray
Pedro
Level 2:
  • Expert 233 Answers
  • Posted on Feb 01, 2015
Pedro
Expert
Level 2:
Answers
233
Questions
Helped
133940
Points
583
1helpful
2answers
How to reset lexmark e260 chip
Go to any website that sells bulk ink and toner refills. They have chip resetters. You need to do this every time you refill . It cannot be bypassed.
How to install a lexmark t644 250 sheet pick arm ***'y in 3rd tray
We do not advice that you remove the pick arm for the Lexmark T644. I would suggest that you contact Lexmark Technical Support or contact a local Lexmark Service Provider (please click on the link below to locate a Lexmark Service Provider nearest to you).
Link: http://bit.ly/UeQhSB
1helpful
I have a lexmark pinter/fax model x646e, i do not have the manual. when i am trying to make copies it reads" 290.01 scanner jam, remove all originals from the scanner" but there is nothing stuck. i have...
This is a hardware issue. Maybe the sensor, the pick arm or the pick roller itself that's causing the problem. Here's an article on Repeated '290' Paper Jam Messages Occur When Using the Automatic Document Feed (ADF) on a Lexmark X64x Series Printer. Just click on this link: http://bit.ly/clBsWr. If this doesn't help, I strongly suggest you contact Lexmark Technical Support to further investigate the problem. Thanks.
Printer says tray 1 low, but paper is not low
Most likely has something to do with the sensor the pick arm's flag. Try to check if the flag is moving freely. If it is, the sensor may need replacement.
3helpful
Error 935.15 Service Printhead error
http://csparts.com.br/csprinter/Lexmark/E360.pdf
hope this link will help u
and dont forget to rank me
3helpful
Thanks in advance. Our E342n Lexmark printer stops printint 3/4 of a page from the end consistantly since I removed a paper jam. I accessed the back panel as directed and removed the jammed paper and since...
It's a possible worn out pick tires, bad pick arm or fuser issue. For the pick tires, you can use the other side of the tires by removing it flipping it. To remove the pick tires, refer to the guide below: 0c29f53.jpg If it's the pick arm or the fuser, it calls for a replacement. But I hope that the pick tires would resolve the problem. If you need more assistance, just leave a comment so I can get back to it.
2answers
25helpful
4answers
241.10 paper jam
Um I don't know what the other guy is saying since your paper jam has nothing to do with where he is telling to look...
From the service manual:
Error 241 subcode 10:
Page was not properly picked from tray 1.
Possible Causes:
Failure to feed possible causes include:
• Edge locking
• Worn or contaminated pick tires
• Overfilling of tray past the fill line.
Action:
Fan media.
Turn media over.
Reduce amount of media loaded in tray 1.
Replace pick tires.*
To replace pick tires:
Integrated tray autocompensator pick roll assembly removal
1. Remove the integrated tray, and look underneath the printer for the autocompensator arm. Pull the arm
down.
2. Press on the end of the tab (A) and pull the pick roll off the arm. Repeat this step for the pick roll on the other side. Next, gently release the autocompensator arm. Discard the used pick rolls.
Installation
1. Remove the new pick rolls from their packaging.
2. Pull the autocompensator arm down. Locate the recessed area on the pick roll, and align it with the tab on the arm. There are two arrows on each pick roll. Make sure the bottom arrow faces you as you align the recessed area with the tab.
3. Push the pick roll onto the arm with the tab aligned. Repeat this step on the other side to install the other pick roll.
4. Gently release the autocompensator arm. Insert, integrated tray.
Thanks and please take a moment to rate this solution as fixya.
2answers
Acer e360
If you TV has a DVI input on it then you can.
Basically this means that your TV has the same connector that your computer LCD is currently connected to on the computer tower.
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
