Refrigerators Logo
Mary Bridgwood Posted on Jan 08, 2015
I am looking for replacement part RF-5310-13 for discontinued Hair Refrigerator Bc230
Everything.
How do I fix my GE refrigerator?
Ge uses a glass heater and it is common for the heater to go out replace the heater and it should cure your trouble
1helpful
No RF out
Some VCR's have the ability to switch off the RF output. You should look under the tuning menu of the VCR.
No transmit
Do you have a model # and brand.? 2sc2312, 2sc2166, 2sc1969. 2sc2028 etc.. are common RF transistors. most are discontinued. but can still be found.. MOSfets replacements are available for nearly any radio.. ERF2030's and IRF520's and there are others. but must be a RF style.
Electrolux ESM6600SA Side by Side Refrigerator getting too cold after a clean
Hello John Wood - From what you have describes it sounds like the damper door might be open causing the temperature to be too cold. Use a mirror to look at damper door at the rear of compartment and use a hair dryer on damper door to deice for 5 to 10 minutes. Allow 24 hours and if the temperature is still too cold, then I would have a professional look at the damper door for replacement.
American crew thickening lotion is the best product i've used because thickens my hair and has great hold but it has been discontinued...can you tell me wich product should i use to replace it?i'm a 27...
if it has been discontinued it will be somewhere on the net as they will sell surplus off try google or amazon or you might get this from america hope this helps
What is a HP J9398A-HP ProCurve RF Manager?
It's been discontinued and and should be replaced.
I just replaced my door seal on my refrigerator and now it won't seal on the lower left corner. I've checked all the hardware and everything looks good. I believe the door has been sprung. Is there...
First, try to use a hair dryer to see if it will seal that way. Then try to let it set all night without opening the door to seal it.
Secondly, look at the hinges to see if they are working properly.
We hope this answers your questions and solves your problem.
Mine freezes up and I too have to use a hair dryer about once
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control. Since your heater does come on but not when it needs to I suspect the electronic control.
3answers
Unotron optical mouse under Vsta HPrm !
The Unotron CS5100 range was discontinued some 3 - 4 years ago and replaced with the WS5100 so I am guessing that the one you have would not support Vista.
Have you tried contacting the place you bought it from, maybe they will switch it for you?
Jon
Top Haier Refrigerators Experts
ADMIN Andrew
ADMIN Andrew
vince
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
