JUMP START SYSTEM Logo
R
Ralph Posted on Jan 08, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a vector 300 amps that will not charge or hold a charge.This is the first time i needed a jump and did not work!It must be a MANUFACTURER DEFECT.What to do? Your Customer
I would like a replacement!I have a vector 300 amps that will not charge or hold a charge.This is the first time i needed a jump and did not work!It must be a MANUFACTURER DEFECT.What to do? Your Customer
AZBen
Level 3:
Sergeant:
  • Master 220 Answers
  • Posted on Mar 13, 2015
AZBen
Master
Level 3:
Sergeant:
Answers
220
Questions
0
Helped
80733
Points
1039
This unit contains a sealed lead acid battery. As such it is necessary to maintain the battery much as you would an RV or tractor or other occasional use battery. If you left the charger plugged in all the time, that's what killed the battery. If you charged it less than once every two or three months, that's what killed the battery. If you stored it in a cold place it may have sulfated. If you stored it in a hot place it may have dried out, especially while charging. The good news is that a replacement battery is not expensive and you can install it yourself. Pull the case apart (look for hidden screws). You may find a good YouTube video to help. Unplug the battery and either shop on-line or go to a battery plus store. But remember, the old SLA battery models like this are rapidly being replaced with LiPoly units that have very good latency (storage) without loss of power. You can get a good one for around $100.
1helpful
2answers
I have a vector 300 amps that will not charge or hold a charge.This is the first time i needed a jump and did not work!It must be a MANUFACTURER DEFECT.What to do? Your Customer I would like a replac
I know how you feel because I had the same problem with mine until I read about the procedure.
Most of those Jump start chargers unfortunately require that you charge them when you buy it and then maintain the charge at least once a month.
There is usually a light on the charger to indicate that the charger is fully charged.
Vector doesn't hold a charge.
How old is it? If it's more that 2 years old the battery needs to be replaced.
Can i jumpstart or charge a motorbike 6 volt battery with a vector 300 amp ??
NO, you will destroy your charging system if it is left on after starting.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
4helpful
My vector start-it elite jump starter is not holding charge even after days of charging. Why?
Hi Ydja,
The batteries on these jump boxes don't last very long. I've been through three of them. Never again.
Now I just carry an extra battery. It's more powerful and has laste longer than the three jump boxes put together.
Best regards
Mike
4helpful
Lost the 12-volt DC charging cord for my vector jump starter
google the name and model #. The home website should come up in search. Go to site, and look in support, or replacement parts.
1helpful
3answers
Everything works but the jumper cables
Most likly the battery is old and will not keep a charge. I just replaced my battery for about $50 a few weeks ago. Go to a story like Battery + for a replacement. It worked for me.
1helpful
Recharging the Vector Start-It compact elite Jump Starter 12 volt
yeah from what im to understand... you charge it overnight, and yes another way to use it (and possibly better way) is connecting to the battery directly..... it should work on your van fine i think, its worth a shot, hope this helps :)
Top Vector Vehicle Parts & Accessories Experts
Sean Wright
Sean Wright
john h
Are you a Vector Vehicle Part and Accessory Expert? Answer questions, earn points and help others
