SOURCE: ricoh color copier service code
Hello sir; Let's try to reset;
1, press "clear mode", "107", then press and hold down "clear/stop" for about 3 second.
2, touch copier SP,
3, enter SP5-810-2 pres enter.
4, press 1, then turn power off and back on .
SOURCE: Solution for "code 373 ricoh aficio color 6513"
Hello sir; the error code you display is toner senser problem, now the first thing you have to do is make a full color copy find out which color missing then pull out developer unit from missing color the senser right underneath, replace it.
SOURCE: error code E 1 on my Ricoh FT4418
please press (.) so we could see the last two number. but most probably check your exposure lamp and thermistor. maybe they are busted anf need to be replaced.
