Have removed the base plate and vertical post, but cannot figure how to remove the hinge receptical in the bottom of the back of the TV. This item must come away in order to wall mount this unit.
The wall mount attaches to the top 1/3 portion of the TVs rear panel. The bottom of the back of the TV should not interfere with your wall mount if it's the correct size. Full instructions are listed starting at page 39 of the manual.
http://downloadcenter.samsung.com/content/UM/201404/20140426112621559/[X13_NA]BN46-00319C-04ENG-0312.pdf
SOURCE: how to remove the stand from samsung LCD TV
Place the tv on its screen flat on a soft surface,
you need to remove all the screws, not just the stand one marked.
Lift the back panel and then you will be able to slide down the stand, when you have removed the back cover you will also see where how your wall mount will fit to the chassis.
Place all the screws back on the back lid.
SOURCE: Remove base of Insignia ns-ltdvd26-09
to remove base from insignia tv
1)remove plastic cover from bottom rear of tv
2)remove 8 philips head screws on rear of tv above base
3)pick up tv and base will come off
once you remove it you realize how easy it is
SOURCE: Removing the stand from a flat panel TV
None of these TVs have any problem removing the stand.
Stands for 32'' and larger TVs plug into the TV's body and are attached by 4 to 8 bolts that go through the cover, then through the plugged-in part of the stand and attach to the internal frame.
In most cases the bolts are 4 - one for each ray of the fork that goes into the TV.
Since bolts for the frame are metal bolts and bolts for the plastic back cover are usually wood-type screws (sharp on the top, wider thread) you can visually tell the one for the stand from the rest.
Look right above the stand for four, six or eight symettrically placed heads that are different from the ones you see on the corners.
Once you unscrew those the stand should feel more flexible and you can simply pull it back.
In order to do all that you have to have the TV laying on its face or back.
Watch out if it's heavy - you may need to support it towards the end of the operation. It's unlikely for it to get damaged if it falls down, but you still don't want to try your chances.
Giving it a little lift also helps unscrew the last bolts...otherwise all the force of the TV is pressing against it...and that makes it harder to unscrew.
SOURCE: Wall mounting Panasonic Viera 32" tv
There's a little more elaboration required on the above post...You need to remember that the base has two long pins that go up into the TV. These pins are held in by two screws each. The screws are on each side of the TV (two vertical inline screws, inside a small inset section). Remove all four screws and the TV will come up off the base. Pull it straight and gently, but firmly, to unseat it from the pins.
SOURCE: how do I remove the stand to mount the TV on the
the TV will mount to the wall via the VESA screw mounts on the back of the LCD. If it is a smaller, monitor sized LCD then the screw pattern will be either 75x75mm or 100x100mm. On larger TVs is it usually 100x200mm. Sometimes the base is screwed into this mount and othertimes to the bottom. Simply unscrew it from the screen. Be sure that the wall mounting kit can handle your LCDs VESA screw pattern, screen size and screen weight.
