Ive hooked it from soundbar to satellite and from soundbar to tv, nothing works. I hooked an ipod to it and that works just the tv sound won't.
Be sure you are hooking up the Audio Output from the TV or satellite to the soundbar.
From the satellite box both Audio Output and Video Output go to the TV, and then Audio Output from the TV goes to the soundbar.
Or
From the satellite box Video Output goes to the TV and Audio Output goes to the soundbar.
This may help as well:
https://www.youtube.com/watch?v=Z27WtBy4IUs
SOURCE: How to hook up a dvd recorder with HTS6500/37?
Suddenly had this problem. My Phillips is hooked up to TV and to Cable Box. When I inserted a DVD it would return a "no disc" but it would read and play CDs. After a call to Phillips...who said that they had no idea what was going on and I should take it in for service...it was 4 months out of warranty. Repair company said it was not worth the repair costs ($200) so I should try cleaning the lens with a lens cleaning disc. I bought a Maxell. It has a set of little brushes on the bottom of the disc. I inserted it and played track 2 for 20 seconds as instructed and voila! It began reading the DVDs again. I was only out the $10 for the disc cleaner. If you have this problem, try the disc cleaner first as it might be the fix.
SOURCE: NO SOUND
Gordon Brady says - go to the 45 Field Support Squadron Reunion in May 2009 and all your problems will be solved. Contact me at gordon brady at hot mail dot com for details please Kev.
SOURCE: How can I reset my Philips Soundbar system
You just remove batteries , unplug all cables, then put everything back together. This will reset the unit to factory settings.
SOURCE: MX 3950D Philips - PS3 no sound
Aside from the xbox360 working via the coaxial digital cable. I got the PS3 to work this way.
I had to use the supplied SCART > (Y-video) (Red-Audio) (White-Audio) cable. Basically plugged this in from the PS3 directly to the MX 3950D Aux (Auxiliary) audio input.
On the PS3 audio settings menu, switched from HDMI to the 3rd option SCART.
Turn on the MX 3950D and set to Aux. Bang, got sound again.
I missed this cause I "assumed" the video/audio cable that came with the PS3 was a HDMI to Audio/Video cable, and didn't even see the SCART port in the back of the PS3. So I thought I didn't want to lose 1080p ..etc etc. Anyways. MX 3950D still good =)
SOURCE: philips HTS8100 owner. Have
Same problem with my HTS8100. Little-to-no sound. Sometimes sound comes on very intermittently. I downloaded the software patch from the Philips website and installed it. This fixed the sound problem for about a week, then the problem came back. I'm not sure what else to do.
