DIGITECH RP500 Guitar Multi-Effects Pedal Logo
Kenneth Moore Posted on Jan 07, 2015
My Wawa pedal went out on my Digitech RP 500 how could I make it work again
Wah wah pedal dont work
Michael
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 28, 2017
Michael
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
649
Points
This might work - Hold the bypass switch for five seconds and follow the on screen instructions to calibrate the expression pedal. If that doesn't work you could also try doing a back up and then a factory reset. You may also consider a separate wah pedal. There are many recommendations at:
What Is The Best Wah Pedal For The Money Our Answer For You
Faucet works sporadically even thought solenoid is disconnected
You are saying that the water comes on by itself? What water pressure do you have?
Service manual schematics
If you open up the unit, you may be able to fix the jack if it has come loose and maybe got a broken connection in the process. It may just be a "cold solder joint" causing the problem
How does the iPod Nike running monitor work?
The Nike GPS monitor fits into your sneaker and you can track your progress on your iPhone or iPod with a special app. You can download the app from the iTunes app store.
http://nikerunning.nike.com/nikeplus/v1/pdf/English.pdf
Jan 14, 2013 • Running
Top DIGITECH Running Experts
Gloria R. Bloomberg
Gloria R. Bloomberg
Sara Patterson
Sara Patterson
Level 1 Expert
Are you a DIGITECH Running Expert? Answer questions, earn points and help others
