Question about Korg Pa800 Keyboard Arranger, 61 Key/USB -
My korg pa800 not found or not reading usb. turn on korg on display ''os not present'' USB ENABLED. please help me
Not found usb for update os
SOURCE:
  • 5 Answers
SOURCE: no sound
1. plug in some headphones into the jack.
2. connect to an amplifier or external source.
3. connect midi to a midi-compatible device and determine if device receives signal by pressing keys
If #1 or #2 passes, your speakers are bad.
If #1 & #2 fail, but #3 passes, your setting are set so that there is no sound, but the keybourd still recognizes input.
If all three fail, the keys do not send a signal at all, you should replace the keyboard.
Posted on Feb 26, 2009
  • 1140 Answers
SOURCE: pcm ram problem for korg pa800
http://www.musitronics.org/ Try here but apparently they are on holidays until August 16. There is also an ongoing discussion athttp://www.korgforums.com/forum/phpBB2/viewtopic.php?t=44624 Hope this helps.
Posted on Aug 06, 2009
SOURCE: Hello,I have a small question re the KORG PA800
there is now homemade solution for pa800 with 128mb ram, i have 128mb in my pa800. but u cant just put new ram, its kinda complicated.
Posted on Sep 28, 2009
  • 5603 Answers
SOURCE: WHAT KIND OF PCM RAM MEMORY IS USED IN KORG PA800
Here is a site IF you are having problem with the PCM RAM. It sounds like you might even get a free replacemnet part.
http://www.korgpa.com/pa_root/en/products/pa800_faq.html
Posted on Nov 20, 2009
SOURCE: os system not loaded! hard drive was totally formated. PA800
Hi, have you solved this problem yet? If you have, share the solution with us please! :)
Posted on Jan 17, 2010
Storejet 25m 500gb not detected in my computer. device driver problem found. device driver software cannot reinstall.
Perhaps you should download updated software of your external hard drive. If still not working maybe your external hard drive is not supported by your OS or isn't compatible with your OS.
Jul 02, 2011 | Transcend StoreJet 25 Mobile 500GB USB 20...
Hi I mestup my Blackberry 7290 by trying to load a new OS now it shows THE 507 ERROR i have found the right os and i still got the backup how do i load it on via usb thanx for your help adien
Hi, Download BlackBerry desktop manager. Install the DM and get the appropriate OS firmware file from the blackberry web site. install it and load it using the DM software. if the connectivity is ok, DM will be prompt to update the OS to the new one. Thanks, Ramaly
Feb 28, 2011 | RIM BlackBerry 7290
My computer will not boot up with the Grandtec Keyboard 2500 dongle in the USB port. Once it boots up, I insert the dongle and it works fine. I had this problem with the Vista OS and now with the newly...
This sounds like a driver issue .... after plugging in the USB dongle, go to the Control Panel>System and Security>System and select Device manager. After Device Manager opens up you should see "Keyboards". toggle open the triangle, to the left of the word "keyboards", and you should see the 2500 listed. If not, right click on the keyboard listed and select update driver software. Then select "Search automatically for the updated driver software". If a new driver is found, it will ask you if you want to use it. If not, try uninstalling the driver that is there and re-booting your computer. Then when you plug in the USB dongle it should automatically install the needed driver.
Nov 04, 2017 | GrandTec Long Ranger KEY-2500 Keyboard
I have a toshiba satellite and after the most recent windows update my external mouse stopped working and says driver malfunction when i plug it in... i have tried everything system restore driver...
Try opening Device Manager in Control Panel and deleting the driver. Reboot, plug the mouse in again and see if that works.
Alternatively try restoring your PC to before your last update.
Dec 30, 2017 | Toshiba Satellite Computers & Internet
My hp1210 printer does not work on window 7 os
This all-in-one should work with the drivers built into the OS. First make sure you have a good data cable (go for a direct cable connection - no USB hub or print server). Next check for updates in Windows Updates. I've had a few printers where the new hardware was found but the driver update was held in Windows Update.
I hope this helps.
(please note that the scan and HP Essentials buttons will not work with the OS driver)
Aug 05, 2010 | HP PSC 1210 All-In-One InkJet Printer
Vista Home Edition Driver Problems
Hi Ajay.
It would be best if you take a back up of important files from your OS drive and make a clean installation of the OS again. There might be an issue of corrupt OS files.
Hope that solves it.
Dec 17, 2009 | Microsoft Windows Vista Home Premium with...
USB recognizes it, but not the OS. I get no drive
Hello, nkhamo
Now, when you say USB recognizes it, do you mean you see the drivers being installed? Because if you are the OS is recognizing something has been plugged in.
Sometimes updating the USB Drivers will be needed. Do that by visiting the maker of your computer and search for Drivers and Updates on their Web Site, look for 2.0 USB drivers class, download that package to your desktop. The driver might be in the form of a Zip FIle. In that case, unzip the files using standard WinZip program or use software provided by computer, to a folder called cab. The driver program might show preference were it wants to unzip to. If so, let it do its thing. Then afterwards find the folder (cab or other folder) run USB driver by clicking install exe file. Note that all periperials need to be unconnected from all USB ports ( the port the laser printer connects to the computer at ) before updating USB drivers. So check cables for solid reconnection after installing drivers.
Its important to recognize the os you have. You'll find that information by clicking on Start Menu > Settings > Control Panel > System.
After doing this update, reconnecting the hard drive via USB Port.
Good luck, jasahasch
Aug 13, 2009 | Western Digital My Book Home Edition 500...
M Box 2 Mini Can not be Found
have you tried Cs updates to your protools software? find the correct one for you by searching Cs updates at digidesign.com sometimes if you update you software, the firmware of your interface gets updated. Hope that helps.
Jul 29, 2009 | Digidesign MBox 2 Mini (USB, includes...
Usb driver for intel 845 GVSR motherboard
u better install windows 7 or updated os in ur system bcoz microsoft had stopped the updates for xp os. so i can say u to install latest updated os to rectify ur problem
Oct 08, 2017 | Microsoft Windows XP Professional With...
USB
yes what is the usb device and the os
Mar 30, 2008 | HP Compaq Presario R4000 Notebook
Korg Pa800 Keyboard Arranger, 61 Key/USB - Logo
603 people viewed this question
Top Korg Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Korg Audio Player and Recorder Expert? Answer questions, earn points and help others
