Hi, Bestwaytrans and the usual suspects are:
1. Fuel tank empty.
2. The fuel tank has old dead gas.
3. Fuel tank bottom contaminated with ethanol sludge, dirt, water, rust, etc.
4. Fuel supply valve/petcock turned off.
5. Fouled spark plugs.
6. Engine flooded as a result of overuse of the choke.
7. Vacuum hose to the fuel supply valve/petcock disconnected, broken, cracked, or pinched.
8. Fuel valve/petcock or filter clogged.
9. Fuel line to carburetor or throttle body pinched, kinked or blocked.
10. Carburetor float stuck.
11. Fuel injectors clogged.
12. Fuel injectors stuck open.
13. Quick disconnect check ball stuck.
14. Compression below 75 PSI.
15. A stuck-bent-burnt valve.
16. Improper valve clearance (too tight)
17. Severely discharged or a damaged battery should have 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a cursory reading of 12.5 volts or more but little or zero amperage the battery is faulty and must be replaced, AGM batteries fail in this scenario more so than lead-acid batteries.
18. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
19. Loose or corroded wire connection at the coil or plug between ignition sensor and ECM module.
20. Spark plug cables in bad condition and shorting check for spark leakage in the dark, cable connections are loose or connected to the wrong cylinders.
21. Ignition timing incorrect due to a faulty ignition coil, ignition module or MAP, CMP, CKP, O2, TPS, ETP, IAC sensors.
22. Faulty neutral, clutch, kickstand safety switch.
23. Faulty fuel pump.
24. Faulty pump relay or fuse.
25. Faulty ignition system relay.
26. Faulty or corroded run/stop switch.
27. Tilt sensor needs a reset.
28. Security system not disarming alarm needs a reset.
29. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below and for more specific information or questions at no charge please feel free to contact me at
[email protected]. Good luck and have a wonderful day.
https://www.hdforums.com/forum/touring-models/987893-help-engine-turns-over-but-won-t-start.html
http://www.mediafire.com/file/lbs9ej75cinadd3/2007+Harley+Softail+Service+Manual.pdf
https://partsfinder.onlinemicrofiche.com/ronnies/showmodel.asp?make=hdmc
https://ownersmanuals2.com/harley-davidson/softail-deluxe-2007-owners-manual-66498
https://www.6ya.com/ to speak to me personally
Runs pretty good from 0-50, give it hell at that speed and its just doggy! Would not do 75 mph. And its not all the time. Also was throwing a code,1 blink then 8 which was a servo problem, but i think that's alright now. Cables are good and both valves move when I move servo by hand. Not showing any codes or engine light is not blinking anymore.
