Its located below the coil distributor...
2002 Hyundai Santa Fe 2 7L coolant temp sensor location Google Search//2002 Hyundai Santa Fe 2 7L coolant temp sensor location Google Search Here are 2 locations with pictures. I found them thru Google in 2 minutes. You should be able to do something with them.
The purge valve is under the car by the driveshaft and looks like this
I do not have specific instructions for replacing these parts, but I think the temperature sensor unscrews. You may want to use a little teflon tape on the new sensor to seal the threads. For the purge sensor, remove the vapor hoses and unclamp it from the bracket. For each sensor, the connector will have a tab you have to press to get the connector off of the part. Let me know if you get stuck or have more questions.
OBD II Code P0128, plenty of coolant and warm-up time.
