Remove or unplug the soundbar from the system and restart the computer. Reconnect the soundbar and check that the LED is lit. If the soundbar does not connect, see if it is listed in Windows Device Manager. Swap the USB soundbar to another USB port.
Try a different USB Port. I've plugged in different USB devices & I've found that some are power ports while others can just be data flow ports. Good device to use is the external DVD W/R. They sometimes have two USB Cables. Like I mentioned above, one is just for data to run back & forth through, while the other port gives the external DVD W/R it's power. Why manufactures don't point this out, probably because it's something that would confuse more than it helped. So try that & see if it helps. Apart from the W/R, it's also helped me to get an external HDD to work. However, I've been lucky with the ones with just a single USB cable, I've either plugged into the correct one, or the Notebooks I've used recognize that there's only the one USB so it automatically discovers it & allows it to work. Hope this helps... DJ
If you have a stereo system that is in the higher bracket area then just connect your TV to the TV input jacks on the back of your amp. Or use the "Phono" input jacks. Nobody listens to vinyl anymore anyway.
The coax out is a digital sound output. You can not use that on your soundbar. The sub out is for hooking the tv to a subwoofer (bass only). You gonna have to use the Headphones output, buy a good 3.5mm to rca cable preferably one with a built-in noise filter so it can attenuate the "hum". Also try lower the volume on the TV so you can have less distortion. That's all!
Be sure you are hooking up the Audio Output from the TV or satellite to the soundbar.
From the satellite box both Audio Output and Video Output go to the TV, and then Audio Output from the TV goes to the soundbar. Or From the satellite box Video Output goes to the TV and Audio Output goes to the soundbar.
Hi, you will need to access the operating manual for your directv remote. It will have codes in the remote. but most likely it will not work your soundbar as most Directv remotes do not have codes for them, and do not support them. You are stuck using the soundbar remote for your soundbar. The only option you can do is to purchase a learning remote from the store that can program to your directv box and your TV, and you can learn the volume keys to your Maxell sound bar.
Amp is probable going into protection mode. Disconnected all speaker and av wires (only power) and check if it switches on. Try to plugged it in also at another wallsocket. Presume PSU damaged by surge
