Tried to find the reset button but could not find it
How can i reset factory setting on my sony ixy 10s camera
Cameras manufactured prior to the year 2000 do not have reset buttons or options in the menus. Follow the steps below to reset:
NOTE: If your camera is experiencing an issue and it is not resolved by performing the appropriate reset or initialize procedure above, service may be required.
Reset button on the camera
Initialize or Reset option(s) in the camera menus
Manual reset process
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
The blurry image capturing can also adjusted by changing the ISO Settings or the Scene Selection modes.
Thanks for using FixYa!
Performing a manual power reset may help:
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settings Menu of the Camera to OK. This will set the user defined settings back to factory default. The images and videos will not get deleted.
Reset the camera to factory specifications to try resolving the issue.
Thanks for resolving the issue.
Hi Nick,
The DSCW210 Camera is compatible with the Memory Stick ProDuo up to 32GB. The Camera will not recognize the Memory Stick if it is formatted in the Computer. Try removing and reinserting the MS and check if it helps. Try using different MS to check if the issue is with the MS or with the Camera. Try resetting the Camera and check if it helps.
· Turn off the camera.
· Remove the battery pack.
· Press and hold the power button for 30 seconds.
· Allow the camera to remain without power for 60 seconds.
· Reinsert the battery pack.
· Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settings 1 Menu of the Camera to OK. This will set the user defined settings back to factory default. The images and videos will not get deleted.
Thanks.
KenSolutions
FixYa
