I've found the cable listed at E-bay and here: http://salestores.com/pak1sucak1ha.html . However, Panasonic has discontinued the SC-HT900 and the cable is out of stock at most vendors. I hope this helps.
The DVD player of this system will output to a TV on either composite (Yellow jack), component (RGB jacks) and S-Video (a small round jack that looks like a mouse or keyboard connector) jack. Since the tint is off, I would guess that you're using the more desirable component or even the S-video jack. Try removing & re-seating the plugs into the jacks at the DVD and at the TV; then check the picture color. If it still is wrong, try using a different cable type - use a standard video cable between the yellow jacks on both the TV and DVD. You may need to set the TV input to reflect the use of the new jack - and possibly set the DVD to 480i or Interlaced if you used the Progressive Scan or 480P output when using component RGB video cables (Red, Green & Blue). Check for correct color.
Chances are the connection got dirty and caused the color issue - or less likely, the cable or even less likely - the DVD output has failed.
From what I can tell from your manual, you do not have auxiliary audio inputs on your system. You can, however, use the TV audio input for sound from your laptop. You will need to purchase an adapter cable that goes from male 1/8" stereo mini plug on one end (your computer jack) to a split (Y) male rca type jack (two connectors for R&L inputs on system. Then you'll need some length of 1/8" male to female miniplug extension cable. You can use the miniplug speaker jack on your laptop as an output. Of course, if you're using the TV audio inputs, and don't want to unplug them to plug your laptop in, you'll need another pair of splitter cables for those rca jacks on your system so you can plug two different pairs of input devices into them, but I'd try to avoid this scenario if possible.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread. If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
This should not be a problem. Cut off the plug off the wire oppisite the sub connection. Turn on the sub and touch each wire till you hear a buzz, that should be your source wire. Connect up an RCA plug with the ground of course, and you should be set. Good Luck
You can get what your looking for here:
http://www.manualdirectory.co.uk/Audio___Hi_Fi_Resources/Panasonic/Panasonic_Home_Theater_Systems/index.html
http://www.retrevo.com/s/Panasonic-SC-HT17-Home-Theater-Systems-review-manual/id/356bh949/t/1-2/
