Question about Kenwood Car Audio & Video
Kenwood KDC-BT558u drains 640 constantly from the Battery even when the unit is off!
Hi, I have installed a kenwood KDC-BT558u on my truck with a brand new battery and everything was working fine, except the battery died when I left my truck in the garage for 3 days! I checked the power draw and it was drawing 640 mA when the car was off and the key was out. I reinstalled the factory unit and measured the amp again and it was only 10 mA. Can someone please help me to understand why the new Kenwood is drawing over 60 times more power than the factory unit?
  • Saeed Soleymani
    Saeed Soleymani Jan 06, 2015
    Just wanted to add that I am aware that the yellow wire is providing constant 12 V even when the truck is off but I cannot disconnect it due to memory loss on the unit.
  • 906 Answers
Check the wire harness connections, sounds like you have KOER power hooked to KOEO. Or in other words, you have power to the radio with the key off that should connected to key on power
Posted on Jan 06, 2015
Testimonial: "Thanks for the comments. I thought the yellow wire is 12V and is connected directly to the unit to retain the settings and parameters!Sorry, can you explain again what you meant?"
SOURCE:
Looking for a Kenwood KDC X397 owner’s manual? .
Yes of course. See the link
hard copy of this Google Search
KDC-MP238/CR KDC-MP208 KDC-138/CR - Kenwood
manual.kenwood.com/files/B64-3898-00_00_KW.pdf
Translate this page
2 ' KDC-MP238/CR/KDC-MP208/KDC-138/CR. Contents. Before use. 3. Basic Operation. 4. General functions. Tuner functions. Disc play functions. General ... Menu Operation. 10. Menu System. Activating Security Code. Deactivating Security Code. Manual Clock Adjustment. Auxiliary Input Display Setting. Receive mode ...
Kenwood KDC-138 CD Player User Manual - ManualsOnline.com
www.manualsonline.com > ... > Home Audio Kenwood > Kenwood CD Player Record the serial number, found on the back of the unit, in the spaces designated on the. warranty card, and in the space provided below. Refer to the model and serial numbers. whenever you call upon your Kenwood dealer for information or service on the product. Model KDC-MP238/CR/MP208/138/CR Serial number.
KENWOOD KDC-138 INSTRUCTION MANUAL Pdf Download.
https://www.manualslib.com > Brands > Kenwood Manuals > Car Receiver > KDC-138 View and Download Kenwood KDC-138 instruction manual online. Kenwood CD-RECEIVER INSTRUCTION MANUAL. KDC-138 Car Receiver pdf manual download. KDC-MP238/CR KDC-MP208 KDC-138/CR CD-RECEIVER INSTRUCTION MANUAL AMPLI-TUNER LECTEUR DE CD MODE D'EMPLOI REPRODUCTOR ...
Connecting Wires To Terminals - Kenwood KDC-138 Instruction ...
https://www.manualslib.com > ... > Car Receiver > KDC-138 > Instruction manual
Kenwood KDC-138 Manual Online: Connecting Wires To Terminals. To Kenwood disc changer/ External optional accessory (KDC-MP238 only) Fuse (10A) Wiring harness (Accessory1) Power control/Motor antenna control wire (Blue/White) TEL mute wire (Brown) Not Used (Blue) White/Black White...
Kenwood Car Stereo Head Unit Replacement Wiring Harness Plug ...
https://www.amazon.ca/Kenwood-Stereo...Wiring-Harness/dp/B005X273W8 Rating: 4.7 - ‎15 reviews
Kenwood Replacement Stereo 16 Pin Wire harness; Top quality all copper 18 gauge leads. Perfect Fit.Molex type 6 inch long black color; KDC KRC DPX KTS models see the descrition for model compatibility; Kenwood power harness plug 16 pin indash radio and video units; Allows for installation of an aftermarket radio ...
Mar 23, 2018 | The Computers & Internet
Kenwood kdc-bt558u radio connector color diagram
Request the diagram directly from Kenwood.
Dec 04, 2016 | Kenwood Car Audio & Video
I just bought a 1994 bmw. I need a code to access my kenwood kdc-x679 excelon player. The previous owner doesn't know the code,
You can enter a 4-digit security code which must be used when the unit is removed from the vehicle, or the constant power source is disconnected from the unit. When constant power is restored to the unit, the security code must be entered before the unit becomes operational.
If the code is lost or forgotten I am afraid the unit has to go to a Kenwood dealer for re-coding.
Mar 26, 2011 | Kenwood eXcelon KDC-X679 CD Player
I cant find the kenwood factory code for a kdc-mp342u radio
If the code is lost or forgotten I am afraid the unit has to be re-coded by a Kenwood dealer.
Good luck with it.
Mar 08, 2011 | Kenwood KDC-MP342U Car CD Player
KDC-215S battery drain
You could add a switch to control the power going to the head unit. I have seen this done in many different vehicles where the head unit drains the battery, even when supposedly off.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Jul 19, 2010 | Kenwood KDC-215S CD Player
Kenwood KDC-MP443U reverting to defaults
i don't think it will blow the unit if swapped...both of them should have power (~positive 12volts)...in the red wire power is supposed to cut off when you turn the ignition key to off...and the yellow wire is supposed to have power constantly(memory)
Oct 01, 2009 | Kenwood Car Audio & Video
Kenwood KDC-MP832U display not working
I had this problem! It was the Cars Battery. Kenwoods unit's fade or go completely blank when there is little power to power the stereo. Try charging your battery or grabing a new one from a scrappy! I was all over the net looking for help but finally sorted it!
P.S. My younger brother had to do the exact thing and it worked for him as well!!!
Jul 20, 2008 | Kenwood 1080VR Receiver
Kenwood KDC 237
There is a YELLOW wire that needs to be connected to a constant + 12 volt source when the vehicle is off.
Best of Luck.
Oct 31, 2007 | Kenwood KDC-135 CD Player
Open Questions:
Car Audio & Video Logo
138 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
