Tried everything in instruction manual ensuring that I had threaded it correctly, searched the internet and tried all suggestions about similar problems.
It is most likely the bobbin not right I'll send u a pic also make such it's not in reverse after u insert the bobbin hand turn it one the need will go down and pic up the bobbin thread once it does pull up on needle thread and it will come up with it all way start with bottom and top thread out the back also make sure tension is set or it will wad up
Testimonial: "Thank you for your input, the bottom thread comes up without a problem, I have tried all tensions but once I start to sew the machine will suddenly stop due to thread getting tangled behind the material and not forming stitches.I have machine sewed off and on for years but have never come across this problem, it is a new machine it should not have any problems."
