Honda 2004 Civic Radio Logo
Jay Tyrone Posted on Jan 06, 2015
What is the code for a compact disc digital audio( anti theft)
loco4cars
Level 1:
  • Contributor 27 Answers
  • Posted on Jan 06, 2015
loco4cars
Contributor
Level 1:
Answers
27
Questions
Helped
9320
Points
55
Contact your local Honda service department. Give them the VIN and they will provide you with the radio code free of charge as long as the car is registered to you.
WANT TO HELP YOU FIND THE CODE OF Visteon 6000CD serial number M195461 ys4f-18c815-aa please help to find code that smile back to my Ford
When you disconnect your battery and then reconnect it again, it disables the radio. This is an anti-theft protection for your car radio.
The enable your radio the activation code is in your vehicle owner's manual. If you do not have this code you need to go to your Ford service centre and get them to enter this code for you.
Acura anti theft compact dis digtal 1xjo need code.
whenever you lose power the radio will go into anti-theft mode and needs a code. this code was provided in the original paperwork with the vehicle. it is printed on a small white label. if you do not have the code take your car to a honda dealership. using your vin no. they can retrieve the code, as long as it is the original radio.
2helpful
Need car stereo code for honda accord 1995
stereo codes for Honda
Method 1 (all applicable models except '03-07 Accords with the navigation system)
1. Turn the ignition switch to ON (II).
2. Turn on the audio unit, and make sure you see stereo COdE in the display. If you don't see this message, pull the backup fuse for 1 minute, and then go back to step 1.
3. Turn off the audio unit.
4. Press and hold the 1 and 6 preset buttons, then turn on the audio unit. The display toggles between two screens. The first screen displays a U and the first four digits of the serial number (for example, U2200). The second screen displays an L and the last four digits of the serial number (for example, L0055). Ignore the U and L, and write down all eight digits.
Method 2 ('03-07 Accords with the navigation system)
1. Turn the ignition switch to ACC (I).
2. Turn on the audio unit, and make sure you see COdE in the upper display. If you don't see this message, pull the backup fuse for 1 minute, and then go back to step 1.
4. Press and hold the top halves of the SEEK/SKIP and CH/DISC bars, and then press and release the PWR/VOL knob. This display toggles between two screens. The first screen displays a U and the first four digits of the serial number (for example, U2200). The second screen displays an L and the last four digits of the serial number (for example, L0055). Ignore the U and L, and write down all eight digits.
5. Call Honda Dealer for Radio Code.
6. Use the TUNE knob to enter the first four digits of the anti-theft code into the audio unit. (Ignore the last digit; it's not used.) When you turn the TUNE knob, COdE disappears, and a single digit is displayed. Turn the knob left or right to select each of the anti-theft code digits. When you press the TUNE knob, the system beeps and accepts each digit as it spells out CODE on the display.
https://radio-navicode.honda.com
I need to get a radio code for a 1999 honda accord
2. Turn on the audio unit, and make sure you see COdE in the display. If you don't see this message, pull the backup fuse for 1 minute, and then go back to step 1.
4. Press and hold the 1 and 6 preset buttons, then turn on the audio unit. The display toggles between two screens:
- The first screen displays a U and the first four digits of the serial number (for example, U2200).
- The second screen displays an L and the last four digits of the serial number (for example, L0055). Ignore the U and L, and write down all eight digits.
If this don't work, definitly you need to call Honda delaer using your VIN.
Hope this help.
10helpful
2answers
2007 Honda Civic Navigation Screen went black
Had same problem with 2008 Honda Civic.
Note: you will need anti-theft code so get it first!
Solution:
1. Turn ignition off.
2. Look for fuse box under steering wheel.
3. Remove fuse #35 which is for the Navi-audio unit.
4. Then re-insert the fuse. This will reset the system.
5. Turn ignition on and the Navi-audio on. Buttons WILL be working now.
6. The unit will request for the anti-theft code for Navi-audio system. Enter the 4 digit code....Yippee!
However, I lost all my radio preset stations. Thankfully my saved destinations in navigation system were intact.
2answers
Won't record record to CD-RW
First make sure your cdrw disc is blank. If it is blank try another good known cdrw brand disc and burn it in 12x speed for a good burn.
If it still fail check the software side of your cd rewriter first and lastly the cd rewriter unit.
1helpful
2answers
Tray B of my RCA CD Burner does not recognize any CDs
Are you using the correct disc type??
The manual states that only discs that are labeled:
"Compact Digital Audio Disc Recordable" (Audio CDR)
*or*
"Compact Digital Audio Disc Rewritable" (Audio CD-RW) can be used.
The popular discs labeled "Compact Recordable" and Compact Disc "Rewritable" are for use in computers, and can NOT be used on the recorder.
Page 16 of the manual shows the graphic of the logos detailed above. The manual can be downloaded for free below:
http://www.retrevo.com/support/RCA-CDRW121-CD-Players-manual/id/19240bh946/t/2/
1helpful
2answers
Car radio
This happened to me. It usually happens when the mechanic takes out your battery. It resets the radio, I think it might have something to do with the anti-theft system.
I wouldn't take the car to the dealer to get the radio code, but to a local auto repair shop. When I took my car to the dealer to have them remove the radio to get the "four digit code" they wanted to charge me $100. So, I went to a local shop, and they removed the radio, punched in the code, FREE of charge.
2answers
Magnavox DVD Video Player DVD609AT
DVD609AT:
The manual is available at Philips website, the number for more info in manual is out-of-date; the new number is 1-800-605-8610
This unit has a problem when playing dual-layer discs of some kinds - read the warnings on the Magnavox website - playing the wrong kind of disc will cause an error that will require svc/repalcement to fix
Playable Discs
This DVD Player will play Digital Video Discs (DVDs) and Audio CDs. In order to play a
DVD or Audio CD on this DVD Player, make sure the Disc meets the requirements for
Region Codes and Color Systems as described on this page. Also, the Discs should have
the following logos and should meet these standards.
• CD-ROM
• Compact Disc-Interactive
(CD-I)
• Compact Disc-Recordable
(CD-R)
• Digital Video Disc-Video
Recordable (DVD-VR)
• DVD-RAM
• DVD-ROM
• Super Audio CD (SACD)
• Photo CD
• Video CD
• Video Single Disc (VSD)
Digital
Video
Disc
12 cm
12 cm
Approx. 4 hours
(single-sided)
Approx. 8 hours
(double-sided)
Approx. 80 minutes
(single-sided)
Approx. 160 minutes
(double-sided)
20 minutes
8 cm
8 cm
(singles)
Logo
Maximum
Disc Type Contents Playback Time
Sound
and
Pictures
Audio
CD
Disc Size
Sound
74 minutes
Disc
Segments
DVDs are
divided into Titles,
which are divided
into Chapters.
Titles and Chapters
are numbered.
Audio CDs are divided
into numbered Tracks, i.e.,
a track may be one song.
Unacceptable Discs
If you insert an unacceptable type of disc, “Please insert a playable disc” will appear on
the TV screen. Also, “- - - - - “ will appear on the DVD Player display panel. Insert a
DVD or Audio CD. The following Discs will not play on this DVD Player.
• CD-ROM
(CD-I)
(CD-R)
Recordable (DVD-VR)
• DVD-RAM
• DVD-ROM
• Photo CD
• Video CD
Top Honda Car Audio & Video Experts
xxxxxx xxx
ADMIN Andrew
ADMIN Andrew
Are you a Honda Car Audio and Video Expert? Answer questions, earn points and help others
