Question about Rotel Audio Players & Recorders
My Rotel RSP-976 analog inputs don't produce sound. I did all the OSD settings but to no avail
No sound coming from my Rotel -RSP-976 analog inputs. I did all the settings on OSD and even reset to factory settings
  • AWAL YAKUBU Jan 16, 2015
    yes i did the OSD settings assigning every inputs to what i wanted. Only the digita plays sound. But no sound from the analogs . Like you aforementioned, it might be firmware problem. But how do i upgrade the firmware
    Problem Solver:
  • 12 Answers
Hi Awal. Interesting problem. Have you tried another pair of leads? What source are you using please, cd tuner etc? I noticed the the names for the five audio/video inputs can be customized by the user, Maybe there is a firmware issue? With the unit being surround sound Have you tried running in 2 chanels only?
Posted on Jan 13, 2015
SOURCE:
bmwrider
  • 215 Answers
SOURCE: Rotel Amp center channel out
Also make sure you have the DVD setup for center channel as well. It and the subwoofer can be disabled in most DVD players. BMW
Posted on May 27, 2006
SOURCE: Rotel rx 1050...Not working
If you are not using the 12v trigger between pre-amp and power amp make sure that the trigger switch on the rear of the RB-1070 is set to off
Posted on Feb 12, 2008
  • 4234 Answers
SOURCE: Denon AVC1530 Amplifier Protection mode
Protection means that the output stage of the amp has detected a problem. Usually this is because there is DC present on the speaker line indicating blown outputs. Figure on $25-$45 for parts plus the local labor rate for the repair.
Dan
Posted on Sep 09, 2008
SOURCE: Denon AVR-790, no sound from Zone 2. Assigned amp
I re-did the connections and voila, it worked,
Posted on Jan 17, 2010
gopakumarg43
  • 76046 Answers
SOURCE: rotel rsp 1098
Hello Eric
Just look at its connections. If the input connections have any loose connections at both ends, of the graound connection to both the devices are not proper, this kind of fault [intermittent sound and static noise] can occur.
Reconnect all the connections and check the connection wires. OK.
Posted on Jan 20, 2012
Getting no sound hooked up to pre-amp and 2 rotel 200w amps with snell speakers
You didn't say whether the player is connected by 2 RCA cables (analog) or by digital cable. If by RCA, does the player have a headphone jack? I had a player once with a piece of a headphone that broke off inside the jack, muting the analog outputs.
May 16, 2014 | Sony CDP-CX300 CD Player
How do I connect Optical Audio or HDMI to Sony MHC-GN100D, to have 5.1 & Dolby sound effects?
I guess you are in the same boat as me.
There are Digital (optical) to analog signal converters available. You can use them. I checked on ebay and here are the converts available on ebay India.
http://www.ebay.in/sch/i.html?_trkparms=65%253A1%257C66%253A1%257C39%253A1&rt=nc&_nkw=optical+to+analog+converter&_ipg=200&_trksid=p3286.c0.m14.l1514
Mar 27, 2012 | Audio Players & Recorders
Rotel rsp 1098
Hello Eric
Jan 19, 2012 | Rotel Audio Players & Recorders
No audio for DVD/CD inputs
Has the DVD settings been altered so that it's now putting out an analogue signal?
Jul 01, 2017 | Harman Kardon AVR 430 7.1 Channels...
My Rotel RSX-972 surround sound receiver has no power, the repair centre cannot isolate the problem and they do not have a service manual to guide them,a service manual would be handy??
Unless yuo can find a Rotel authorized service center, you are not likely to find any service information. These units should not be difficult to repair. Their designs are pretty much standard with a few twists. Any shop that handles audio repair should be able to resolve this. If not, please post your location and I'll try to locate a shop for you.
Also, are there any indications that the unit is trying to work at all or is it completely dead?
Thanks,
Dan
Mar 25, 2009 | Rotel RX-965 Receiver
NO SOUND - APOGEE & SPEAKERS HOOKED UP
possibly obvious... but on the maestro control / settings  meter display /output /input
Dec 02, 2008 | Apogee Ensemble Sound Card
114 people viewed this question
Top Rotel Audio Players & Recorders Experts
 Grubhead
Grubhead
Mike Duncan
Mike Duncan
Are you a Rotel Audio Player and Recorder Expert? Answer questions, earn points and help others
