How to change battery
SOURCE: Jabra SP5050
Not all models of Bluetooth earphones are compatable with every phone. Contact Apple support to find out if the model you have is compatible.
If the Apple tech says that the model earphone is compatible, then you should try another earphone to verify if the iPhone Bluetooth section is defective, or if the earphone you have is defective.
Jerry G.
SOURCE: LG enV2 cannot locate my Bluetooth device Jabra SP5050
Followed step by step of pairing instruction of Jabra SP 5050 manual on the Web.
Thanks
SOURCE: jabra sp5050 can you please tell me the factory
Try 0000! It's the standard bluetooth code for most bluetooth enabled devices unless changed.
SOURCE: I have a Jabra SP5050 hands free device for the
Press and hold the button on the Jabra for 10 seconds until the LED starts blinking. This puts the headset in "discoverable" mode so the new cell phone will be able to see it for pairing.
If your phone prompts you for a pairing code, try either 0000 (four zeros) or 1234
SOURCE: Can't pair or connect Jabra
My Xperia X10 cant find my handsfree device nokia BH 105. Please help.
