Computers & Internet Logo
MALCOLM ROBINSON Posted on Jan 05, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My disc is not playing nor can I eject it is there some way I can do this I have a Lenovo Think Centre M90z
CALLED LENOVO SAID I NEED A NEW DVD DRIVE . I NEED TO EJECT THE DISC , I EVEN INSERTED S PAPER CLIP AND NOTHING HAPPENED. DO YOU HAVE A SOLUTION
bzet1820
Level 3:
  • Master 700 Answers
  • Posted on Jan 05, 2015
bzet1820
Master
Level 3:
Answers
700
Questions
Helped
211688
Points
2147
You did not stated which operating system you use, but if vista or win7, before you do anything drastic -
1. lmb (left mouse button) click "start" button (bottom left corner)
2. lmb "mycomputer" or whatever show your drivers
3. rmb (right mouse button) click your "cd-rom" or whatever name you give it
4. lmb "eject"
if it work - you are fine, drop in some music or video disc (which you know work on other computer) and try play again, hold your fingers on the door to determine if disc is spinning, or even put disc in specific way and then after closing the doors, check if light lights up and disc spin, open the door and check if disc is in same position, if so - disc do not spin... most probably will need replacement, or buy yourself usb dvd/bluray player as i done for my wife laptop, cost me $39.00 instead $150.00...
if eject command did not work then follow this procedure:
all cd/dvd/blueray drivers have mechanical safety latch, straighten up your paper clip, find little hole on the front door of the drive and insert perpendicularly the clip into it, press slightly till latch give and door opens few mm (sometime there is much more than just "slightly"), physically then extend the doors and retrieve your cd/dvd.
look closely as it may resemble light, and one of them will be diode but other will be hole. if memory serves on this model latch hole is about 1mm diameter and it is located above the manual eject button.
hope this will help you to solve your problem, do not forget to vote
Ken Labudda
Level 1:
Problem Solver:
  • Contributor 16 Answers
Ken Labudda
Contributor
Level 1:
Problem Solver:
Answers
16
Questions
0
Helped
2254
Points
42
The drive can be easily removed once removed you can then use the paper clip from the back and push the tray open
3answers
How can I play a dvd movie on new lenovo laptop with Windows 8.1
once you insert the dvd in your laptop,it should asking you what to do in a box.You can choose to play the media and etc.If there is no box pop up,you can try open media player like cyberlink dvd or vlc player, go to file >open media from your dvd player.
Cd drive not detected
This is usually a sign that your disc is corrupt or that the drive itself has failed.
3answers
Have it blu ray?
As a follow up to this, what's the easiest way to convert that .mkv file to a more size friendly file? Which program will keep the best quality and what would you suggest as size?
Computer Support ' Dell Support
Lenovo Z570 Disc tray is stuck -outside of laptop
Open the try slightly, shut down the machine, tilt the machine to the side of the DVD/CD drive a gently shake to loosen the tray or whatever is causing the problem, Is the disk off the spindle? Is the dvd/cd broken? Can you insert something to clear whatever is obstructing it? Have you tried to eject using the software, Go to computer, right click DVD/CD rom drive, click on eject? Has there been any damage to that area, bent..etc? You may have to force it open or remove the drive and try to open it.
Compact Disc rewritable DVD player won't load or play
Check the data connector on the rear of the drive. If this doesn't work you may need a new drive, they are cheap and readily available.
3answers
Describe how you insert a dvd into a laptop
Hi Eunice, just want to clarify, for lenovo notebook if it doesn't have DVD drive you can use external DVD drive to access DVD CD. DVD external drive is just plug and play device once attached in your USB port, it will automatically detected and once detected you can use it already. Just install Burner application to burn some files if your DVD is capable of burning CD.
3helpful
How can i eject a stuck CD/DVD from disk drive of a levovo ideacentre A600? I didn't find any emergency-hole. please help.
Welcome to Fixya.
Try booting in BIOS mode by tapping on 'DEL' or 'F1' key as soon as you turn the computer on (while seeing the LENOVO screen). When in BIOS, you can eject the disc.
Thanks for using Fixya.
18helpful
2answers
Can't open DVD drive on Lenovo ThinkPad Tseries
Hello
Thank you for using
FixYa for your problem
there is a little hole that a paper clip will slot into, thus pressing the release catch inside
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Top Lenovo Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
