I cannot reach the jammed paper as it has gone too far
There should be a panel on the back where the power cord is that you can easily take off to get to the paper.http://www.usa.canon.com/cusa/consumer/products/printers_multifunction/office_all_in_one_inkjet_printers/pixma_mx452?CMD=MIXED_SEARCH&mName=PIXMA+MX452&mType=PIXMA+MX&pageKeyCode=ekbresults&searchString=paper+jam&BASIC_SEARCH_CURRENT_TOPIC_ID=3715&BASIC_SEARCH_CURRENT_TOPIC_TYPE=0&RESULTS=RELEVANCE&RELEVANCE_START=1&RELEVANCE_COUNT=25&CONFIGURATION=1011&PARTITION_ID=1&TIMEZONE_OFFSET=null&USERTYPE=1&isSecure=false
1.
1 Switch off the printer and disconnect the power
supply. Allow any residual charge to fade away before putting your hands or
metal tools inside the chassis.
2.
Step 2 Pin down the exact location of the jam. The
three hot spots for a jam are the paper tray, anywhere between the feed tray
and the print carriage, or between the print carriage and the output tray.
3.
Step 3 Take off the front paper tray if the sheet got
stuck while it was still in the front area of the printer. If the sheet jammed
here, you should be able to see most of the paper.
4.
Step 4 Pull on the sheet with both hands and steady
pressure. Do not tug as you might rip the paper, leaving a chunk of it deeper
in the machine.
5.
Step 5 Open the back panel to reach paper jammed
between the feed tray area and the print carriage of the all-in-one printer.
Carefully remove the jammed paper from the machine.
6.
Step 6 Use the carriage access door to reach a jam
further inside the all-in-one printer. You may need to move the print carriage
out of your way to clear the jam.
7. Step 7 Return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
