Serial no. 84252077 str/job no 07/03. Adjust temperature to colder for both fridge and freezer and left glass of water for 2 hrs. Adjusted temperature gauge again to middle of colder/less cold, left glass of water for another hour. Still no sign of both fridge and freezer cooling or freezing. Can hear the motor running, and light in fridge works.
You are either low on freon refrigerant, or your compressor is frozen (usually due to low freon) or your compressor is bad. the motor will cycle on and off even though the compressor is not working. the refrigerator away from the wall and look compressor will be a nerf football sizedand usually black cylinder. It could be very hot or cold/frozen. can also unplug the refrigerator leave it for a few hours and plug it back in if it work you are low on freon. You need a repairman
