just bought this relic? box? and expect it to work in W10? what?
tell all connections and all related equipment (gear) and OS run.
we can not ever guess others networks. wired or wifi.
not.
MOTOROLA WPS870G Wireless Print Server 802.11b / g, RJ45 LPT, USB 2.0
a true Blast form the PAST 2005 for worse, older printers.
LEGACY relics, I can do.
the manual is here. free 115 pages,
the topic first is , what printers work here, not told yours.
the box new has CD with XP driver, and are useless now.
so what then>? you never said XP or up to W11 use.
it really is a print server, that is for sure and wireless so you can print from any wireless PC to the unstated parallel LPT printer of old
page 8 quote
"Windows IPP Client software is supplied for Windows 98SE and Windows ME computers. IPP support is built-in to Windows 2000 and Windows XP
computers."
the rear of the PS, has LPT 25 pin (dinosaur) and USB that
runs wired printers this way, but I bet newer printers USB fail here.
easy as pie (eating cherry pie slang)
NO PRINTER TOLD BUT I GUESS USB PRINTER AS LPT ARE ALL DEAD NOW, RIP ,LPT 25PIN PRINTERS.
the manual covers both things wifi setup and USB printer and test print pages.
my guess is your setting up the PS , wifi pages and it fails?
read page 15 and for sure direct printer app that is useless today xp apps are that.
the wifi on the SP must be set as a fixed IP in your home router, using mac address of the SP. MAC = IP , RESERVED. FIXED
OR TROUBLE MAX.
THE IP MUST NOT CHANGE, PER PAGE 15 TOLD
"the printer must be on the the allow list
?My printer
doesn't show up in the list of available printers during installation.
If you are using an USB-enabled print driver to connect your printer to the Wireless Print
Server, you might need to download and use an Ethernet-enabled print driver. You will also
need to use IP Printing (LPR) if you use an Ethernet print driver. See
PAGE 73
WPS870G
LPR Printing
Setup"
step one, after used PS is reset. fully
the wifi must be setup wifi. page 49
https://www.manualslib.com/manual/106781/Motorola-Wps870g.html?page=49#manual
17years old
XP tell me you do not run XP.
